EWG question, when should it open?
Old Apr 25, 2011 | 11:46 AM
DerekB707's Avatar
Car Info: 07 rs STi swapped Rotated BW S200SX-56
Hi,
I have a tial 38mm vband wastegate. I am installing the .9 bar spring, which is roughly 13.05psi. Should the wastegate begin to lift at .9 bar or be fully open at .9 bar? I brought it to work today to test and am noticing movement at ~10psi.
Thanks!
Derek
Old Apr 25, 2011 | 09:34 PM
tommysyko's Avatar
Sounds like its working well. Had similar setup and with the boost line and tune you'll be good to go. My tuner had the boost controller set so the ewg does its job and holds the levels for the turbo for the optimal tune for what your look for (ie high numbers, daily driver, or autox etc.)
FL4T
Jun 21, 2012 10:38 PM
verc
Mar 15, 2011 06:26 PM
BBKG79
Apr 21, 2009 04:27 AM
gesundlich
Mar 17, 2009 01:40 PM
