evo motor can make more power then sti
Old Apr 8, 2004 | 04:32 PM
TurnWRX's Avatar
trade your sti for an evo
Old Apr 8, 2004 | 07:27 PM
DLUX WRX's Avatar
the evo bottom end is pretty strong. ive heard that the EJ25 just hasnt been around long enough to be fully developed. the Evo block has been around for a while so Mitsu has been able to get most of the kinks out of it.
Old Apr 8, 2004 | 10:04 PM
When you start making BIG power numbers Subaru motors will always start to fall behind. the features that make it so torquey in stock trim (essentially the long intake and exhaust runners) become restrictions when you try to flow lots and lots of air and make 600 hp. It's a fact of life. If you want a 12 second back mountain road terror, I'll always take a Subaru. If you want an 11 second car, start with an inline 4 if you want a small motor/big turbo combo.
Old Apr 8, 2004 | 10:42 PM
MARKSTI's Avatar
With light mods the EVO and STI are pretty close,....but start throwin cams and other stuff into a EVO and it will start makin more hp then a STI...........the MAIN reason being of the FAR better factory turbo..........and better FMIC setup.
I think Vishnu is still using the fairly small and heat soak prone factory top mount intercooler...?????
Upgrade the turbo and add a front mount intercooler like the EVO has, and it should even the playyin field.........to a degree....
Old Apr 9, 2004 | 12:49 AM
Cyrus923's Avatar
Car Info: 2004 WRX in WR Blue
No Crap, evo can have more hp. WRX is still best
Old Apr 9, 2004 | 10:12 PM
SlickmisterN's Avatar
Car Info: 2004 Black/Gold STi
Youve got to understand that the evo motor has been around for a really really long time.
Old Apr 13, 2004 | 02:53 PM
thebankman's Avatar
Car Info: subaru
I agree 600hp is a lot to expect from a 2.5 liter four cylinder.
But also consider that there are classic VW bugs that make lots of power out of engines less than 2.5 liters. It will take some time for tuners to find that much power from Subaru's engine, but it'll happen eventually.
Old Apr 13, 2004 | 03:31 PM
JohnQGearhead's Avatar
Car Info: '00 RS, Subrosa Letum
www.rigoliracing.com
nuff' said!
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
Rivers
Aug 14, 2008 11:04 PM
Sti-nkinPhast
Aug 22, 2003 09:32 AM
Sti-nkinPhast
Aug 22, 2003 03:16 AM
