EJ25T dropped into a MY00 2.5RS?
Old Feb 29, 2004 | 05:04 PM
JohnQGearhead's Avatar
Car Info: '00 RS, Subrosa Letum
The block bolts right in except for a little filing or grinding to make room for some condensor hoses, but if you want to swap the whole thing it will be a much bigger issue.
Another guy around here did the short block swap and said it was relatively painless. He used the SOHC heads and stock wiring harness which is probably the best way to go. You could just build a turbo setup and buy a stand-alone ECM, then just cross your fingers untill the tranny blows up.
RAGEWRX
Sep 4, 2006 02:35 PM
blue5spdwrxwgn
17
Sep 11, 2005 10:05 PM
Imprezinator
Jan 9, 2003 11:31 AM
Imprezinator
Dec 3, 2002 12:14 PM
Imprezinator
Nov 27, 2002 10:03 AM
