Cylinder 1 Misfire!! Need Suggestions!!!
Old Oct 10, 2007 | 06:19 PM
imHELLAslow's Avatar
Car Info: 20psi Daily!
Unhappy Cylinder 1 Misfire!! Need Suggestions!!!
hey guys, I drive a 2006 wrx with 30k miles and recently swapped a vf39 & sti tmic and am running the cobb vf39 map.
i also recently started throwing a Cylinder 1 Misfire code. At first i thought i just got a bad batch of the 91 cali **** gas, but it started coming on a little after every fill up.
im not sure what steps to take first, should i change out the plugs with oem ones? or go ahead and switch to one step colder plugs? also, what is the gap i should be using? Please give me your thoughts or suggestions. thanks in advanced.
mods are
vf39
sti tmic
cobb ap, vf39 map
bosal divorced dp
hks carbon ti
k&n drop in filter
Old Oct 10, 2007 | 06:27 PM
pj21086's Avatar
any other mods??? are they oem plugs??? flywheel??? pulley???
Old Oct 10, 2007 | 06:30 PM
dmoneywrx's Avatar
Car Info: 2017 wrx
my car is doing the same thing with an 02 wrx but i hav a pully.. i have been thinking about taking it off. does a pully even make any different in power??
Old Oct 10, 2007 | 06:38 PM
i added the mods up top. yeah, they are oem plugs, never touched them. stock flywheel and no aftermarket pulleys.
Old Oct 10, 2007 | 08:49 PM
anyone??
Old Oct 10, 2007 | 08:50 PM
subie OCD's Avatar
Car Info: 04 STi
Take it to a local tuner, GST would probably be closest.
Old Oct 10, 2007 | 08:55 PM
subie OCD's Avatar
Car Info: 04 STi
From my research on nasioc, ngk iridium plugs are already gapped, so if you do switch them yourself, I wouldnt recommend messing with them. There is a spark plug faq on nasioc if you want to check it out.
I just rechecked your mods...doesnt that map require STi pink injectors????
Old Oct 10, 2007 | 09:22 PM
Thanks for the info man, ill check out the faq.
as for the injectors, the cobb website said that i dont need injectors due to the 06 wrx's having bigger injectors.
Old Oct 10, 2007 | 09:53 PM
subie OCD's Avatar
Car Info: 04 STi
ahhhhh yes, I overlooked that. I still vote to take it to a tuner and/or get a custom tune. Cobbs maps work, but in the end a map specially made for your car is the most efficient. Good luck!
Old Oct 10, 2007 | 10:42 PM
thanks. i already have an appointment this friday at GST, but im hoping to get that problem fixed before the tune so i dont have any problems. do you think theyll be able to diagnose the problem?
Old Oct 10, 2007 | 11:17 PM
subie OCD's Avatar
Car Info: 04 STi
This is just one part of the modding game - risk.
Hopefully its something maintenance related thats easy to fix, with these types of problems you just have to trouble shoot one step at a time, spark plugs, fuel pump, fuel filter, tune.....has the k&n drop in filter been cleaned recently? Ive heard that the k&n filters do indeed flow more....but get dirty VERY quickly. Hopefully its something simple like that.
Old Oct 10, 2007 | 11:20 PM
subie OCD's Avatar
Car Info: 04 STi
Ive never had a pulley on my old wrx or my current STi but Ive read that it helps the engine rev a tad faster....not increase horsepower.
Old Oct 11, 2007 | 02:30 PM
midnitewrx's Avatar
CHANGE your plugs 1st. def do a step colder. cheap maint . i have barely no engine mods an i changed mine at 30k. iridium 1step colder. MMmmm
Old Oct 11, 2007 | 08:25 PM
do you happen to have the part number for ngk iridiums that are one step colder? and are they already gapped to what i need? or will i need to gap them? thanks
Old Oct 11, 2007 | 08:44 PM
03_Impreza_Al's Avatar
BKR7EIX11
http://www.subaruparts.com/catalog/?section=937
at the bottom.
I think.
