crackling noise upon hard accerleration?
Old Apr 24, 2004 | 05:57 PM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
my apologies if its been covered.
lately i've noticed when i "pound" it and the rpms clim5 grand and higher i hear what sounds like my turbo making a crackling noise. . . any input ?
Old Apr 24, 2004 | 07:13 PM
ej25lvr's Avatar
Car Info: 04 wrx sti
sorry to say but its most likely detonation or could be wastegate flutter which some get confused. its easy to get confused if you have never heard them seprately. detonation kinda sounds like bb's in a can.
Old Apr 25, 2004 | 04:34 AM
gdogg's Avatar
does detonation occur only @ certain rpms.? that crackling noice doesn't always happen- is there also a rpm "flutter" ?
Old Apr 25, 2004 | 09:34 PM
acarguy's Avatar
Car Info: STI
From what I've experienced and read most people have experienced det in the 3.5-5k range.
Someone really needs to get the reflash working in Hawaii......or you can be like me and just run a costly mix = to about 94 octane. I havent had det ever since
Old Apr 26, 2004 | 02:41 AM
RoadSpike's Avatar
The ecu's on the STI having been giving pretty much everyone det problems. Subaru reflashed a friend of mines quite awhile ago when he talked to me about the problem. No det or knocking since
Old Apr 26, 2004 | 09:24 AM
STiDayDreamin''s Avatar
Detonation is most likely to occur at or around 4k RPM's while going WOT uphill in 4th thru 6th. (at least that's what I remember from my research prior to taking delivery...pretty sure it's accurate though). Good luck man - let us know what happens.
Old Apr 26, 2004 | 12:18 PM
blitzjza80's Avatar
Car Info: 04 STi
oh, I think I have the same problem too.
Old Apr 26, 2004 | 02:57 PM
SlickmisterN's Avatar
Car Info: 2004 Black/Gold STi
Its deff. detonation. Try some high octane fuel and see if it goes away. If it does its detonation.
Old Apr 27, 2004 | 12:51 AM
go go go's Avatar
Car Info: GF8 ver6
yup, get a little bit of 100 octane gas and try see if its gone.
If it goes away with 100 octane gas its knocking.
Old Apr 29, 2004 | 02:51 PM
gdogg's Avatar
thanks for the tips guys, i'll post more results soon
Old Apr 29, 2004 | 04:19 PM
v rod's Avatar
Car Info: Real Slow
Re: crackling noise upon hard accerleration?
yup!
the dreaded sound of det!
Old Apr 30, 2004 | 01:21 PM
gdogg's Avatar
crap! VROD, how long do you think i have to fix this problem? am i in danger if i run too long with that problem. . . i had a quick fix
check me out here-
https://www.i-club.com/forums/showth...065#post526065
