Cobb Stage 1 or Exhaust First?
Old Dec 8, 2005 | 05:01 AM
UK Scooby's Avatar
Car Info: US 2006 STI , JDM STi V5 Type R
So all the peoplle with with Cobb mods. Was the Accessport fitted first or did you go with turbo back exhaust changes first? Apart from the lucky people who did the complete stage 2. Also, what is reliability like, any problems?
Regards,
SMF
Old Dec 8, 2005 | 05:42 PM
gruppe-s's Avatar
Hi - It's cheaper to do an uppipe/downpipe, then get the Cobb AP later. Once you get the Cobb AP, you'll be able to run the stage 2 map instead of the stage 1 map. You shouldn't have any reliability issues on doing either mods 1st.
Let me know if you have more questions.
thanks,
Preston
Old Dec 28, 2005 | 08:17 PM
powerband's Avatar
thanks,
Preston
For the '06 WRX with an already catless (OEM) uppipe, is it necessary to replace it with an after-market uppipe in order to do the Cobb stage 2 map?
I've been contemplating doing the Cobb TBE first, and then several months later do the AP (stage 2). Is this possible? Please advise
Thank you.
Old Dec 29, 2005 | 02:27 PM
DomozitoLK's Avatar
Highflow or catless downpipe is the requirement for Stage-2...not uppipe.
Originally Posted by cobbtuning.com
Q. What is needed for Stage 2?
A.
We actually field a lot of calls with people wanting the Stage 2 AccessECU because the dyno graph looks a lot better, but they do not have a turbo-back exhaust. Here is a diagram of the exhaust to help you visualize:
The Stage 2 was tuned on a car with a full turbo-back system. If you have pieced together a less than optimal combo of parts or those that were not designed to work together you may not get the full benefits of the Stage 2 AccessECU. Boost may not come on as quickly and the peak power may be down from those that have a well designed full turbo-back system. If you have replaced the first section (second cat or downpipe section) and nothing else, then the Stage 2 map is what we would recommend. Again the results will be far less than optimal, but it will control the boost better than the Stage 1. If you have replaced sections 2-4 (third cat, mid-pipe, and muffler section then you are still Stage 1. You managed to get all except the part that makes the most difference. Again, we want to reiterate that Stage 2 will only get the intended results with a well designed complete turbo-back.
Old Jan 3, 2006 | 07:14 AM
Weakness's Avatar
Car Info: 2005 Subaru WRX STi
Thumbs up
Great info DomozitoLK, thanks for sharing! Pictures make this easier to understand...
srbaugust
15
Jun 2, 2013 02:02 AM
enzo350
Nov 3, 2006 07:49 AM
enzo350
Hawaii Classifieds
Nov 3, 2006 07:47 AM
casualsurfer
May 3, 2004 03:24 PM
00b5
Mar 29, 2003 02:00 PM
