cobb intake w/box vs stock w/protune
Old Feb 1, 2009 | 10:42 PM
nation's Avatar
Car Info: 2006 sti
i know the shelf maps dont support cobbs sri w/box.but for the people running a pro tune has there been a noted increase between the two?i have the sri and considering the box.
Old Feb 2, 2009 | 12:23 AM
LxJLthr's Avatar
Stick with the stock air intake box, it is good for up to ~400 hp, and just get a good drop in filter. I actually gained 10 whp/10 wtq when I re-tuned my WRX after switching from the SPT sri that came on my WRX as dealer installed option. There is plenty of documentation here and NASIOC regarding this issue, but the summary is that any aftermarket intake will allow for greater heat soak and inconsistent MAF readings. Consequently, these do not present optimal tuning conditions and hamper the tuner from extracting the most out of your set up. You only need a intake with a FMIC or a high horsepower set up. However, considering that I still gained power with a stock airbox on a built 20G turbo that was already putting down over 300 whp, it says a lot (at least to me) about the stock part's efficiency.
Old Feb 2, 2009 | 06:14 AM
soobedup's Avatar
Car Info: WRX wagon 2006
I'm really surprised on how many people suggest the stock box overall out performing any aftermarket intake boxes. I just purchased off craigslist an SPT air box. I'm gonna install it today. i'm excited but wonder if LxJLthr is right about sticking with the stock would be better when I eventually protune my car and all its upgraded parts.
Old Feb 2, 2009 | 09:24 AM
LxJLthr's Avatar
Well, I was skeptical myself before the change, but I cannot argue with the dyno numbers and how much noticeably smoother the car idles and performs. However, I am not sure if my results are typical considering I have a pumpkin size turbo installed (meaning my changes will always be greater), but I still think the same situation will apply with lesser mods. If anything, your power numbers might not change between the two set up, but rather the smoothness and power delivery will be affected...but again, that's just from personal experience and speaking with other people...
If you still go with the SPT, make sure to at least get the SPT heat shield as well and wrap the body of the intake with some sort of heat shielding material to lessen heat soak as much as possible since its body is cast iron. IMHO the intake does make the stock BOV, turbo spool and engine noise a lot better sounding.
Old Feb 2, 2009 | 10:36 AM
soobedup's Avatar
Just cleaned the used SPT intake gonna let it dry for awhile...It came with a heat shield for a great deal. Major mods I currently have now are Helix catted DP, Greddy Evo2 catback exhaust, and the WORX bov. I need to adjust the bov because it's giving me bad idling and after that I will install the SPT airbox. So happy took today off from work!
Old Feb 3, 2009 | 12:19 AM
nation's Avatar
Car Info: 2006 sti
keep me posted on the results.anyone else want to chime in
tyflip2
Dec 16, 2013 11:01 AM
s2kvee
Mar 31, 2013 12:31 PM
sanjosuby
Dec 8, 2010 11:18 AM
Irishdude
Mar 23, 2007 08:06 PM
