Borla hush cb... Dp?
Car Info: 06 STI
I'm running a borla hush cb with cobb ots stage 1 on my 06 sti. I want to get a bell mouth dp but there are so fn many. I don't know which one will mate up & if the o2 sensor will reach or not. I hear a lot about down pipes not fitting correctly & I'm trying to avoid any custom work. Or should i go with one brand tbe? Suggestions please.... Or a cobb tbe if anyones selling one.
I'm running a Titek catless DP w/ Stromung dual tip cb and everything mated up perfectly and o2 sensor reached easily. If you're going w/ catless, I don't think it matters much though. Good luck finding a DP
Car Info: LUMPY CGM 05 WRX
Any DP should do. The borla has the sleeve in it that is adjustable for length as well as position.
I am running a helix catless and it works fine.
I am runnning a borla hush
Nobody likes the tuna here
Everything should be fine except Megan DPs IMHO mine did not fit right although different chassis. Also consider if you're ever going to get a wideband that it has the bung at the top also.
johndabrit
Apr 8, 2010 09:13 AM
06scooby
Oct 6, 2006 10:47 AM
Crisisback
Jul 20, 2004 08:25 PM
