Blow Off Valve Help
Old Jul 24, 2009 | 04:48 PM
skiingwrx's Avatar
Car Info: 2007 wrx
Blow Off Valve Help
Hey guys,
So I am thinking about putting a Greddy RS blow off valve in my 2007 Limited WRX. The engine is stock right now but work is going to be done soon. Will the blow off valve screw up my engine? One of my buddies, he drives a jetta, warned against me putting this part in. I really want to do it, but I wanted to check with people that know more then I do. Thanks for any advice given.
Old Jul 24, 2009 | 05:10 PM
ZeroGWRXGG's Avatar
Car Info: 02 WRX Sport Wagon
From personal experience, I would wait until all your engine work is done. My engine builder ended up recommending a stock STI air bypass valve (BOV). I originally got the car with an aftermarket adjustable BOV and I bought a HKS BOV. I like the sound but there was no real performance advantage (with a stock engine). Most of the rally cars use the stock assembly. But, again from personal experience I would wait until you finished your build and then go from there. I ran the HKS for almost two years before I got my engine built. It did not cause any problems.
Old Jul 24, 2009 | 05:17 PM
Originally Posted by skiingwrx
Hey guys,
Do. not. put. it. on.
Just do a simple search on here and it will tell you the same
Old Jul 24, 2009 | 09:09 PM
PikkaGTR's Avatar
remove the stock snorkus---presto! free BOV sound
Old Jul 25, 2009 | 03:17 AM
Rickdrizzle's Avatar
Car Info: 2001 2.5rs
You can put it on, but it'll run crappier than it was when it was stock.
How much crappier? Probably not by a lot.
Is it worth it? probably not.
Old Jul 25, 2009 | 04:40 AM
subi4justin's Avatar
Car Info: 2015 SWP WRX
There is no benefit to running an aftermarket BOV. Just keep you stock BPV on there
Old Jul 26, 2009 | 10:55 AM
Traxamillion's Avatar
Car Info: nothing
man you guys are a bunch of wussies!! ive been running hks/turboxs rfl for 2 years straight on my 06 wrx. car is fine. some people dont have the knowledge. i use bov's just for the sound, if your doing track or something staying stock would be best... but your not doing track are you.
Old Jul 26, 2009 | 11:35 AM
VRT MBasile's Avatar
Stay with the stock one.
Really, so yours doesn't idle poorly compared to the stock BPV? That must be some magical BOV
All it takes is a simple understanding of what the BPV/BOV does. The air it is letting out into the atmosphere the engine is expecting to come back through the intake tract, so it puts fuel into the cylinder because that air is supposed to be there. What happens then? TONS of unburned fuel.
Old Jul 26, 2009 | 11:58 AM
I call bs on the poor idle, at least in my case.
I ran the HKS ssqv for months and the car ran the same as it did when I had the stock bpv. Granted, I only daily it and never raced with it.
Old Jul 26, 2009 | 12:00 PM
:IBthingsgetheatedinhere:
Old Jul 27, 2009 | 01:31 PM
knock's Avatar
Car Info: bici putas
total BS on the poor idle.
Tell me how, at idle, the BOV is open.
Yeah, at idle (or just open loop) the car runs off MAF voltage directly, but at idle there's not enough load to spoolup, therefore the popoff is never activated. There could be long term fueling corrections due to rich conditions on throttle closing, but this won't **** with idle. It will if you rev your engine like paul walker.
Do what you want; an aftermarket blowoff has the ability to move more air, much faster than the stocker. It also holds high boost more effectively (if it doesn't suck) Recirculate it if you don't want to do major tuning for it.
Old Jul 27, 2009 | 03:17 PM
skiingwrx's Avatar
Car Info: 2007 wrx
I think that I would be using the part just for the satisfaction of the noise. No I will not be racing the car either. I have just graduated college and I am not making a lot of money right now. I just want to be sure that if I put this part on I wont have to buy a new engine in like a year.
Old Jul 27, 2009 | 03:23 PM
in theory it shouldn't affect idle, but poor craftsmanship throws theory out the window. I threw on a cheap BOV that came with a buddy's TMIC and the idle was low and rough. Perhaps I overdid it with such a generalization, but BOVs CAN cause rough idle, not all of them will though.
Old Jul 27, 2009 | 06:37 PM
knock's Avatar
Agreed, low and rough idle can be caused by vacuum leaks, and I bet that cheapo bov was the culprit!
If this is your modification algorithm, buy a catback instead. Way better sound to $ payoff.
The only reason I have my turbonetics raptor is that I have lots of custom piping/turbo/pressure needs. It's set up recirculating, and sounds mighty fine also.
Recirc unless you're running a Holeshot diesel compressor at 30psi.
RallySportDirect
Engine and Drivetrain
Nov 24, 2009 12:54 PM
Black797
Aug 17, 2007 09:15 PM
BoostedRex
Mar 10, 2004 10:33 PM
Ninosautoacc
Vendor Group Buys/Specials
Feb 24, 2004 10:39 PM
dgflwrx
May 12, 2003 02:21 PM
