Blouch WRX/STI Dominator 4.0XT-R
Old May 28, 2010 | 07:21 AM
1reguL8NSTi's Avatar
Car Info: 05 STi
Alright,
I'm working on building the ole' STi (05) up. I'm currently in Iraq and haven't had the chance to post in a while but here goes. I'm really liking the characteristics of the Blouch 4.0 XTR and it seems to be a great bang for the buck. My issue is I'm not sure what other supporting must are a must with this thing as far as a motor build goes. Is this stock block compatible or should I go ahead and build it up? Any advice would be greatly appreciated.
Thank you
Old May 29, 2010 | 10:11 AM
Concillian's Avatar
Car Info: 02 WRX sedan
Isn't this basically a stock location 35r?
You're pretty much rollin' the dice on stock pistons whether or not they have a casting defect. You might get lucky, might not. Heads are getting pretty restrictive at 35r level too, but that can get $$$
Old May 29, 2010 | 11:18 AM
SR20steve's Avatar
Car Info: Evo X GSR, F250 Powerstroke Diesel
I'd lean towards the not lucky, lol.
Old May 29, 2010 | 04:34 PM
Car Info: 05 STi
Yeah, same here. That's what I'm wondering. I'm looking for 400 realistically to start and I've read nothing but good things on the Blouch set-ups. SR20steve, I had an F-250 too before I got to Iraq. Great trucks.
Old Jun 4, 2010 | 11:09 PM
im2ninja4u's Avatar
Car Info: Fully Built 08 STi Full-Race Borg'd TS 83-75 :D
You should probably at least do pistons and some headwork. I have a cracked Dom 4 that's being sent to Blouch tomorrow to get upgraded to XTR that I won't be using.
Old Jun 5, 2010 | 01:16 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
The Dom 4 is a good turbo and is comparable to the ATP 35R stock location. Its definitely recommended to at least have some upgraded pistons with this power level. That being, said, I've tuned a good deal of cars with this power level with stock motors that are holding up just fine, but its definitely a gamble.
-- Ed
Old Jun 6, 2010 | 07:25 AM
Car Info: 05 STi
Yeah, as far as I'm concerned anything above a stock turbo is a gamble so I understand the chance of things going BOOM I'm just trying to limit that. So if you were going for approximately 450-500 on 93 what would you recommend?
And im2ninja4u, let me know when you get your turbo back, I might be interested. Turns out I'm going to be in Iraq for about 4 months longer than I expected.
Old Jun 9, 2010 | 04:27 PM
Car Info: 05 STi
Nothing?
Old Jun 10, 2010 | 08:17 AM
im2ninja4u's Avatar
You might want to factor in Meth injection.
Old Jun 10, 2010 | 11:46 PM
Boost Addict's Avatar
Blew a piston at 24k miles on the car with Dom 3 XTR tuned to 373whp at only 23psi. Just dropped in a new built block with Mahle pistons, H-Beam Rods, ACL bearings and will be expecting 425+ whp around 26-27 psi on CA-91.
We've seen 460whp/500wtq on the same dyno with my tuner, same turbo running meth.
The 3.0 XTR has great spool characteristics and makes great power to 6k rpm. But if you want power to continue past 6k rpm, look into the 4.0, but expect later spool time.
Old Apr 23, 2013 | 09:55 PM
007_STI's Avatar
Car Info: 2007 Subaru sti
When you had your Dom3 what mods were made to your car? and I hear and read if you keep the psi under 20 the motor is still fairly reliable? I do plan on rebuilding my motor when I get out of the army and go to school in a year but I want to change out the turbo my seals are shot and I'm leaking oil that's why I'm asking about the dom3
Scoobyx
Cars For Sale
Sep 13, 2014 11:26 AM
BOHICA
Mar 17, 2012 07:08 PM
Boost Addict
SoCal Classifieds
Jan 4, 2012 11:55 PM
jagstyle
Sep 14, 2009 09:56 AM
Never Slip'N'
May 7, 2009 02:30 PM
