Anyone tried "seafoam"?
Old Jul 29, 2013 | 12:16 PM
Tren Hard's Avatar
Overbear's Power Bottom
Hey my stepfather uses this in his Nissan pathfinder and he loves it. Asked if I wanted to use it. Was unsure if it was safe for my car. Anyone used this stuff?
His pathfinder has 212k miles on it and says it drives better now than it did at 125k miles when he just started using it. His car has never had any major fixes to the engine either, all stock and still runs strong. Here's a pic of the container.
Old Jul 29, 2013 | 12:35 PM
04GG's Avatar
If in doubt, FLAT OUT
Maybe you want some slick50 to go with it?
Old Jul 29, 2013 | 12:50 PM
Harry Maneuvers's Avatar
Car Info: 04 WRX Wagon, 06 Forester XT, 99 Legacy Sedan
I have used it on the 04 WRX and the 99 legacy but only through the intake.
It is good for a cool smoke screen for sure.
The difference in drivability was nominal if any although I know others who rave about it. I think it is more for piece of mind. I have not yet seen engines with comparable miles/usage opened and examined where one was using seafoam regularly and one.
When I cleaned the top of the pistons on my EJ251 donor block just before the build, seafoam did the absolute best job (of all liquid cleaners I used) for actually dissolving and removing the carbon deposits.
Before:
After:
FYI Subaru makes an upper engine cleaner that is essentially the same thing. There are TONS of threads on multiple forums about seafoam use in subaru's if you have a good 36 hours to kill reading them.
Old Jul 29, 2013 | 01:06 PM
queeg9k's Avatar
posting pics from funkyjunk
Old Jul 29, 2013 | 06:59 PM
Tren Hard's Avatar
Before:
After:
Thanks for the info man. Appreciate it! Think ill pick up some "upper" tomorrow. Can't wait to buy time exhaust for my car next.
Old Jul 29, 2013 | 09:19 PM
04GG's Avatar
Every dealer has something like that and they charge a lot for it usually. I've had it recommended to me a few times on higher mileage cars but really never saw a big need for it. My S13 had 222K mi on it and it still ran great. How many miles on your car?
Old Jul 30, 2013 | 12:59 AM
Tren Hard's Avatar
76k rightnow
Old Jul 30, 2013 | 07:37 AM
04GG's Avatar
There are no doubt some deposits on the car at that mileage, but it is still low enough that I probably wouldn't do it if the car is running fine.
Old Jul 30, 2013 | 08:09 AM
SkizzDawg's Avatar
Car Info: 2006 STI
Doing it at lower mileage rather than higher helps get deposits now before they become larger. I wouldnt myself rush right out to do it but if you have the can, the time and know what your doing why not?
Old Aug 7, 2013 | 11:18 AM
iin10ded's Avatar
Car Info: audi
ive had very good results with it in past cars. made it a standard part of oil changes. lil bit int he fuel, and oil a few miles before a change, then smokescreen it via intake then change oil/filter.
car always runs noticeably better. you can let the deep creep set up on top of the valves overnight if you have bad deposits there.
Old Aug 9, 2013 | 10:29 PM
Tren Hard's Avatar
Thanks mate. I'm gonna go through with doing it all tomorrow. Oil change in how many days later, 100miles?
Old Aug 9, 2013 | 11:02 PM
oaklandish_WRX's Avatar
Car Info: 0[[XXXXoXXXX]]0
Ehh, prevailing wisdom is 200-500 miles. With your miles, prolly only 200. Just did mine and it helped idle and throttle response. 2002 at 106K, stock.
Also confirmed an exhaust leak I suspected.
Old Aug 9, 2013 | 11:05 PM
DarkJuic3b0x's Avatar
Car Info: EQ Tuned * Corn Juiced '05 WRX
Like others have said, if you have the can and the time, definitely do it.
I've done it before in both my gas tank and through the intake. The seafoam through the gas tank doesn't make much of a difference (as far as I could feel), but the seafoam through the intake was a big help.
If you do seafoam through the intake, you'll need an extra pair of hands. Have a buddy help you with it.
Let us know how it goes!
Old Aug 9, 2013 | 11:06 PM
as far as the oil change goes, look at your oil dipstick often and you should be able to see how effective it its.
Old Aug 21, 2013 | 08:34 AM
Heedz's Avatar
Nobody likes the tuna here
Throw some tren in engine, built immediately.
wagonrasa
Feb 22, 2009 01:10 AM
DetailAddict
Jan 16, 2007 10:30 PM
VRT MBasile
Nov 2, 2006 10:20 PM
808subaru
Nov 16, 2005 08:59 PM
subie OCD
Oct 19, 2005 11:50 AM
