2006 STI reving problem
Old Oct 19, 2006 | 04:38 AM
scrawshaw's Avatar
When I lift off the thottle and push in the clutch, the revs climb for a bit before dropping back down. It seems to happen in every gear. Kind of scary when you shift at 6k as the revs go to 7k by themselves before you let out the clutch again. The car has done this since day one and has about 2k on it. This behavior might actually make the car easier to drive smoothly, but is this normal?
Old Oct 20, 2006 | 11:52 AM
klenboy's Avatar
Yes, it's because of a slight delay due to the electronic throttle. Although I'm not claiming all electronic throttle-equiped cars do this. But do they???
Old Oct 23, 2006 | 08:40 AM
impreza-tux-121's Avatar
Car Info: 2006 Impreza WRX Sti/Hawkeye
oh yeah haha i found that out as well. but try letting go of the gas petal before you step on the clutch. i just got used to it so i dont over rev anymore. iono but it only happens on sti's like he said up there its the throttle response. SSLLOOWW!!!
Old Oct 23, 2006 | 08:41 AM
no. the evo doesnt do it. i drove an 03 evo and it responds right away!! then i drove my sti and found out i cant shift that fast hahha. SUCKS!!
Old Oct 23, 2006 | 11:41 AM
Me&05WRX's Avatar
Car Info: 2015 STI
That occurs on my WRX. I would shift and watch the needle slightly jump up, along with the engine sound. And yes it does make shifting smoother for me. I have read couple of threads about the same issue, so I think it might be a normal occurence.
Drackonan
Oct 18, 2014 09:49 AM
Irish_car_B0mb
Apr 10, 2008 03:07 PM
808_rex_808
Apr 26, 2007 06:03 PM
knight
Jan 23, 2007 07:49 PM
