07 STi Catless?
Old Sep 21, 2008 | 09:51 AM
BayAreaSTi23's Avatar
Car Info: 03 Evo 8
07 STi Catless?
Anybody running 07's catless with cobb ots stage 2 map? Im installing a catless downpipe on friday and gonna just flash the cobb ots stage 2 map untill a get a pro tune sometime next month. Ive read about the boost creep issues with the 07's. I ordered the larger restrictor pill from subaru, i heard that helps with the boost creep.
Old Sep 21, 2008 | 06:26 PM
1sicwrx's Avatar
The pill might help but generally it's kind of common to have boost creep issues... It's kind of a hit or miss. You might have issues, you may not. Good luck with the install.
Old Sep 21, 2008 | 07:40 PM
Car Info: 03 Evo 8
Thanks I hope everything goes smoothly. What about an aftermarket boost solenoid does that help?
Old Sep 21, 2008 | 10:37 PM
A170123W's Avatar
Car Info: 2007 Subaru Impreza WRX STi
boost creep
On my 07 sti im running cobb catback with a catless nvidia downpipe on a custom stage 2 map provided by gst motorsports. I have no boost creep, also when I was using the AP stage 2 OTS map I didnt have any boost creep. I think you should be okay, just make sure to get a tune if you do.
Old Sep 21, 2008 | 10:50 PM
STINGR's Avatar
Boost creep is a mechanical issue. I would highly recommend getting a protune since you have a 07 sti and see if that helps. Your tuner should be able to play with the waste gate duty cycle.
Ron
Old Sep 21, 2008 | 11:51 PM
Car Info: 03 Evo 8
Im hoping for no boost creep at all. I'm definetly getting a protune but I'm gonna have to roll on the Cobb stage 2 ots for a couple weeks.
Old Sep 21, 2008 | 11:57 PM
Car Info: 03 Evo 8
By the way what kind of numbers did you get after the gst protune? And what kind of mods do you have? I'll be runnning a greddy ti-c with a titek catless dp
Old Sep 24, 2008 | 02:33 AM
A170123W's Avatar
I went to GST to get my tune from Mike, I put down 267 AWHP and 292 Torque on pump 91 Gas. Keep in mind the GST dyno is called the "heartbreaker" other dynos would of read a little higher.
Drew's rex
Apr 2, 2009 08:33 AM
gesundlich
Oct 30, 2005 10:09 AM
mepp
Subaru OEM Parts For Sale
Aug 8, 2003 11:39 AM
gpatmac
Dec 12, 2002 12:24 AM
