06 wrx stage 1 cali maps Vs. stage 1 map?
wat would happen if i run a non cali maps? is it safe enough for me to run it? right now im running cali stage 1 as a base. pls help. thanks
I would stick with the CA specific maps for added safety with our crap gas. I don't think you'll be leaving any noticeable power on the table by running the CA map.
Try running a RT stage 2 and CA stage 2 back to back. See if you can feel a difference in performance or if you notice any detonation. Get a protune if you want to be safe. |
it's all in the octane, most of the Cali maps are set for 91 while others are set for higher octane that's available in other states
[QUOTE=johsti]I would stick with the CA specific maps for added safety with our crap gas. I don't think you'll be leaving any noticeable power on the table by running the CA map.
Try running a RT stage 2 and CA stage 2 back to back. See if you can feel a difference in performance or if you notice any detonation. Get a protune if you want to be safe.[/QUOTE] i dont think i can run Stage 2 without a downpipe, thats my next goal then illl get it protuned. i think imma stay with stage 1 cali maps. are u running cali maps? how is it on urs? any problem? |
I'm running CA maps, and everything has been fine. I'm getting a tune on Monday, so I'll soon find out how safe my CA map is when I do a base run.
according to cobb's site the difference is only like 5 hp. Not enough to risk any damage. If you really want to run a 93 map throw some octane booster in you tank first
[QUOTE=lburrrna]wat would happen if i run a non cali maps? is it safe enough for me to run it? right now im running cali stage 1 as a base. pls help. thanks[/QUOTE]
I think your talking 91 stage 1 vs 91 CA stage 1? Well I am running non CA 91 stage 2 and have been fine so far. I always use good gas no AM PM and have noticed no problems. |
are you from california? if not of course you can other maps.
[QUOTE=lburrrna]are you from california? if not of course you can other maps.[/QUOTE]
Yeah, I think he's from California. Elk Grove is up near Sacramento. |
Ya I am from CA...
you might get pinging if you dont run the CA map
