06 STi shaking (rough idle)
Old Mar 24, 2007 | 12:37 AM
ST-ISUS!!'s Avatar
Car Info: 06 STi
I noticed that my STi shakes or feels like its trembling when im at idle.. for instance at a traffic light..my friend who sat in the passenger seat said he also felt the car shaking..we both can feel it through the seats..i dont know what doing this but any thoughts would be nice..my STi is stock..for now..
Old Mar 24, 2007 | 12:43 AM
azn_ryder02's Avatar
Car Info: 2007 Satin White Pearl STi
STi will shake a little at idle theres not really a problem if really want to get rid of this issue get yourself an aftermarket balanced crankshaft theres all sorts of benefits to be had with that
Old Mar 24, 2007 | 09:10 PM
05Redsuby's Avatar
Car Info: 05 OBP STi
Mine does the same but i think its normal because my 05 wrx did it also
Old Mar 24, 2007 | 09:18 PM
VRT Gump's Avatar
how long have you had it? I thought there was something wrong with the car at first, but its normal. I have an 06 WRX and it does the same thing.
Old Mar 25, 2007 | 02:08 AM
ST-ISUS!!'s Avatar
Car Info: 06 STi
i had it for about 4 months now..but its nothing to worry about so im good
Old Mar 25, 2007 | 05:59 PM
vodka's Avatar
Car Info: 4日本車
Mine doesn't idle rough enough, I def need wild cams so my sti idles like a big block V8 and spills liquids in the cup holders.
Old Mar 27, 2007 | 11:14 AM
GT35 STI's Avatar
Troll
Car Info: 2008 Legacy Spec-B
it's an 06 sti... the motor mount probably gave out
Old Mar 27, 2007 | 11:50 AM
gte123v's Avatar
Car Info: 06 WRB STi
^^^I agree. you might want to check the engine mounts and the pitch stop, see if they are cracked, especially the engine mounts since they are plastic.
Old Mar 27, 2007 | 11:53 AM
scarface's Avatar
Car Info: 2005 WRX STI
yeah it shouldnt shake that bad at idle stock. Check the motor mounts. How about when you do a take off? Does it shake as you give gas and let out clutch?
Old Mar 30, 2007 | 07:24 AM
BlaKKStaRR's Avatar
Car Info: WRX 2007
yea its probably because the engine is horizontally opposed and causing the shaking...thats waht i've heard at least...its commin on all subies
Old Mar 30, 2007 | 07:34 AM
soggynoodles's Avatar
umm no. i dunno about that one. If it's just minor shakes then it's normal. My 05 does it. (and it has solid mounts)
Old Apr 10, 2007 | 06:36 AM
stormhalter's Avatar
Car Info: 2006 STI
06 STI here. No rough idle or shaking for me. Just small vibrations here and there in the shifter when gripped, but that's normal.
It doesn't hurt to check your mounts though. (:
Old Apr 10, 2007 | 08:07 PM
wind's Avatar
Car Info: 2006 STi
Yea, i remember reading on Wiki that '06 STi got plastic motor mounts and they do crack. But Subaru will change them to rubber ones if they cracked though...
Old Apr 11, 2007 | 10:16 AM
Car Info: 2006 STI
Ugggh, seriously? I have to look into that. Pffph.
That's a bit unnerving.
Old Apr 30, 2007 | 02:16 PM
blacktraxgirl's Avatar
Car Info: 2006 STi 2012 STi
my 06 sti does it and i know that its normal...its worse on really hot days.
