You Downpipe Opinion
Old Mar 20, 2004 | 09:19 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Originally posted by vteg
The downpipe cat is a bigger restriction than the third cat. I am sure you can get 300chp with the stock third cat.
Stromung sells a 3 inch cat pipe.
I dont think you can go stage 2 with the factory 3rd cat, you will probable need a high flow cat.
Old Mar 21, 2004 | 03:48 AM
McBain's Avatar
Car Info: WRX Shooting Brake
I have a Bosal DP and a Borla Hush, with 250 wheel hp. I'm going to replace the factory cat with a Stromung high-flow cat in a few months. I think it may get me 5-10hp or so. Mine is a daily driver as well, and it isn't way too loud. The Cobb and PDE high-flow cat downpipes are way outta my league right now.
Old Mar 21, 2004 | 07:04 AM
DizzyWRX's Avatar
I think vteg is right
Old Mar 21, 2004 | 09:48 AM
MO REX's Avatar
To go cobb stage 2 you only need to get rid of the cat in the stock downpipe.
Your probable correct. The only reason I thought You needed High flow instead of factory is because if you buy stage 2 package comes With turbo back exhaust.
Old Mar 22, 2004 | 01:34 PM
drwrx's Avatar
If your just looking to go cheap for now, pick up either a Bosal or Stromung downpipe, then later, if you decided to add a larger turbo, pick up a 3" mid pipe with a high flow cat. Stromung would be the obvious choice, since it will mate up to the dp and your Borla hush.
Rally Performance's STi Hunter uses the stock 3rd cat with Scooby Sport dp, cat back and ECU reflash and puts down nearly identical numbers as Cobb's stage 2, so I think you can get away with the stock pipe for now.
Old Mar 26, 2004 | 09:14 AM
ride5000's Avatar
Originally posted by Georgethefierce
This is pretty much my set-up...........gutted stock up-pipe, Bosal Downpipe, stock mid-pipe (w/ 3rd cat intact) and Bosal twin tip cat-back................It'll keep you happy for a little while!
next stage: get your hands on a spare OEM midpipe and smash the cat out of that.
that's what i did. it resulted in even more grinning!
jm2c
ken
