Is XS Engineering High?
Old Dec 3, 2002 | 04:27 PM
1quikrex's Avatar
From: Perrin Race DP Perrin Up-pipe Blitz Nur-spec CB Blitz LM intake TXS UTEC GFB BOV
"All these benefits of added performance are generated with less than 150rpm of additional turbo lag." -XS Engineering website.
This quote was in regards to their front mount for the wrx, they are saying the difference between a fmic and tmic in terms of lag is 150RPM. I thought the lag was much greater than this, am I wrong?
Old Dec 3, 2002 | 04:39 PM
Choku Dori's Avatar
Car Info: Corvette Z51
If this were indeed truly so, XS Engineering would have my business You sure they didn't mean 1500rpm? That'd be more reasonable hehe.
Old Dec 3, 2002 | 04:42 PM
1quikrex's Avatar
That's what I was thinking.
Old Dec 4, 2002 | 06:53 AM
Z1 Performance's Avatar
this statement is vague though..no mention of setup, ecu, etc...all of which affect lag..the turbo and IC are just 2 components in the equation..timing map, fuel map, boost, etc. are all factors in determining lag.
Old Dec 4, 2002 | 07:56 AM
OakosAutomotive's Avatar
Car Info: 2002 WRX OAKOS Edition
How can lag be measured by RPMs? Lag, if it were to be measured, would be measured in time. Maybe they meant boost threshold? Boost threshold being the earliest RPM the turbocharger would create positive manifold pressure.
Old Dec 4, 2002 | 03:22 PM
IgotWRXed's Avatar
Car Info: ayo for yayo
lag can be measured in rpms as to where the boost came on before and after.
Old Dec 4, 2002 | 03:58 PM
It is actually possible to get les lag with a FMIC...jsut takes the right combo of parts...again, their statement is too vague
Old Dec 4, 2002 | 04:21 PM
1quikrex's Avatar
So which combos out there have been known to have minimum lag when compared to stock. I'm looking at garrett gt's.
Old Dec 4, 2002 | 05:44 PM
"Where the boost came on" is boost threshold not lag.
Lag is the amount of time it takes the turbocharger to creat boost when hitting the gas, making the assumption that the engine is in an RPM range which allows the turbo to create boost. Lag is measured in time.
Threshold is the earliest RPM that the turbocharger will create boost. Threshold is measured in RPMs.
This is all covered in Corky Bell's Maximum Boost, if you don't already own it, buy it now!
-Dave
Old Dec 6, 2002 | 05:24 PM
There are countless turbos out therer....Garrett GT's are among them, but requires all sorts of custom work.
For a bolt on upgrade utilizing some Garrett GT parts, there are the various hybrids offered by many of us out there including XS Engineering .
Adam
www.z1auto.com
Old Dec 7, 2002 | 12:04 AM
IgotWRXed's Avatar
-Dave
thnx for the suggestion, but my comment goes under the assumption that 90% of the people out there can not differentiate threshold from lag.
Old Dec 8, 2002 | 09:35 AM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
............I think XS somewhere said that they get like 14 HP just from their intake alone.
Old Dec 8, 2002 | 12:49 PM
Choku Dori's Avatar
-Dave
I learned something new today. Thanks Dave! *scurries out to buy Corky Bell's Maximum Boost*
XS Engineering's a funny little company
Old Dec 8, 2002 | 05:00 PM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
I'm pretty sure Turbo XS' dyno always makes numbers that are on the high side. You can't really compare HP #s from two dynos made by different manufacturers because they are clearly going to be calibrated and used differently. The main use of them is to find relative changes in power and torque.
Fade2Black
May 8, 2003 05:40 PM
codger
Jan 26, 2003 06:50 PM
advtechsport
Vendor Group Buys/Specials
Dec 11, 2002 12:04 AM
grifter_mp5
Dec 4, 2002 02:39 PM
