WRX Uppipe
Old Aug 19, 2003 | 05:03 PM
bone324's Avatar
Car Info: '02 WRX WRB
The best uppipe is the APS tapered uppipe with flex joint in my opinion. However, no one has ever tested uppipes against each other to see which one is best or if there is any difference at all. Some people think the flex joint is better than a solid design, others think the opposite. APS says the tapered design improves the exhaust speed, improving turbo response. Makes sense to me. Is it worth $100+ more?
Old Aug 19, 2003 | 07:42 PM
awns729's Avatar
Car Info: want a WRX
Perrin is also good...i dont know too much about them but im pretty sure everyone here thinks perrin is one of the better companies
Old Aug 19, 2003 | 08:00 PM
awns729's Avatar
www.worldoneperformance.com
www.vividracing.com -expensive
...there are many other sites..but i dont really know them ...maybe someone else can tell you where to buy it...or search on yahoo or something..do more research before u buy one
Old Aug 20, 2003 | 10:28 PM
DLUX WRX's Avatar
I also have the Helix up pipe. It was a pain in the *** to install, just like other up pipes, but im pretty pleased with it. You can feel a little extra power when on the freeway. The Vishnu intructions were really easy to follow, and you'll save a lot of time if you leave the turbo heat shield off.
Old Aug 21, 2003 | 06:38 AM
ride5000's Avatar
nothing fits like OEM!
gut it and save ~200 bucks.
if you don't like that option, go for the STi catless pipe.
remember: it's just a foot long section of pipe!
jm2c
ken
Old Aug 21, 2003 | 09:48 AM
mmboost's Avatar
I really doubt they all perform the same In terms of flow, the widest pipe (to a point) with the striaghtest path and well made joints will provide the best flow. So, you want wide enough to accomadate the inlet to the turbine and you want, here's the real issue you're looking at, quality that leads to long life.
IMO, a gutted stock is going to be much better than an ungutted stock, but its not going to be as good an aftermarket pipe. Stock has a small internal diameter, and while not chocked by cat material, its much smaller than aftermarkets as well as its internal diameter changes throughout the pipe. Certainly not optimal characteristics.
Look for pipes without a history of leaks that are of a decent size and decent manufacturing quality and you'll get a good deal. I have the Perrin and I've loved it from the moment I got it. In fact, I sleep with it at night.
jason
Old Aug 21, 2003 | 10:49 AM
ride5000's Avatar
widest pipe = greatest flow, but at lowest velocity. not good if your intent is on spooling up a turbine.
i agree that the step changes in diameter with the gutted stock pipe are less than ideal, but i guarantee you that at the levels of performance most of us are achieving it makes NO DIFFERENCE WHATSOEVER. in fact, there was a test on this board comparing gutted stocker vs. aftermarket, and the variation was meaningless.
save your money, and spend it on a nice downpipe NOW, since gutting that pipe is not the best solution at all (wastegate issue). besides to get to the up pipe you've got to remove the DP anyway, so best thing is to do it all at once.
i've got a stock up pipe i'll sell it to you for 30 bucks shipped. diy without being stressed about downtime. if you want me to gut it give me 80 and it's a deal. i'll gut it within 3 days.
ken
