WRX engine tick
Old Jun 16, 2004 | 01:55 PM
DJTEN4's Avatar
Car Info: 03 yellow wrx
my engine went through this phase for about a week where when it was cold it clicked, i donno what it is, i was about to take it in, but then it went away!
Old Jun 18, 2004 | 10:00 PM
Lurk's Avatar
What kind of motor oil are you using? Its normal for the EJ20 to tick when cold. Using a quality synthetic oil will make some of the ticking sound go away.
Old Jun 19, 2004 | 01:02 PM
supra_man's Avatar
mine used to tick when i used that chevron with tecron crap, now i use 76 and it runs fine
Old Jun 20, 2004 | 04:05 PM
RoadSpike's Avatar
from my limited understand the tick would be caused by a slightly sticky valve. You could try pouring a small amount of Marvel Mystery oil into the crank case and see if it can loosen up your valves a lil.
This may not be the problem but if you had some MM handy it would be worth the shot
Old Jul 13, 2004 | 12:56 AM
raazin's Avatar
Car Info: 2002 wrx wagon black
or you can put a little bit of atf fluid good luck
tmp111111111
Mar 25, 2006 08:26 AM
bassplayrr
Apr 15, 2004 11:45 PM
bassplayrr
Apr 13, 2004 05:39 PM
t-wrexxx
Aug 28, 2003 05:53 PM
