WRX (EJ20) limits
Old Apr 20, 2004 | 07:13 PM
Xarch20's Avatar
Car Info: 2004 Silver WRX
Exclamation WRX Limits
how much HP can the stock internals take also how much can the sock transmission take. thanx.
Old Apr 20, 2004 | 07:24 PM
SlickmisterN's Avatar
Car Info: 2004 Black/Gold STi
First you should have searched, second you should have posted in the EJ20 forum, and third to answere your question the WRX motor can handle alot of HP the stock transmission has trouble handleing stock HP.
Old Apr 21, 2004 | 06:53 PM
SnoHumper's Avatar
Car Info: sc300
stock transmission my guess is it can handle about 180 crank hp LOL! engine i think like 350 or something? maybe 400
Old Apr 21, 2004 | 07:54 PM
awns729's Avatar
Car Info: want a WRX
I've search for similar topics and found some crappy results. Maybe he did search, maybe not. Whatever. The tranmission is fine for the stock WRX if one doesn't pop the clutch or do high RPM launches. However, under those driving conditions the clutch will wear out or the transmission will break eventually, depending on whether or not the clutch is slipped or popped.
Now, there are people with stock internals and stage 4 setups that are running with no problems. 350+ HP isn't even a big deal, really.
Old Apr 21, 2004 | 10:39 PM
thebankman's Avatar
Car Info: subaru
My car makes 216hp at the wheels with the "updated" 02 WRX clutch and stock transmission. As long as you're slow and steady on the clutch it feels very good, no clutch burning yet, and it's been about a month since the car was put at that horsepower number and no problems yet. I would estimate the stock clutch and tranny cannot handle much more power than this...also as I said you have to go slow with the clutch thought i'd reiterate that.
Old Apr 23, 2004 | 04:56 AM
wolfen42's Avatar
Re: WRX Limits
My biggest problem pushing higher than 300 FHP was the tendency of the sock transmission to unravel at high speeds...
-Spy-
Canada
Oct 20, 2004 12:56 PM
Wingless Wonder
Apr 21, 2004 09:12 PM
hashiriya
Nov 24, 2003 11:00 PM
turborambler
Feb 28, 2003 12:36 AM
Kevin M
102
Jan 28, 2003 11:21 PM
