will 02 wrx ecu work in jdm 94-97 wrx
Old Mar 8, 2004 | 05:45 PM
mrmodex's Avatar
will this ecu work with this motor and a 1.8 wiring harness
Old Mar 9, 2004 | 05:34 PM
go go go's Avatar
Car Info: GF8 ver6
Why dont you source a 94-97 WRX ECU? its much easier.
If you car is 93-97 EJ18 Impreza, the JDM 94-97 WRX ECU should plug right into EJ18 harness with no mods. All you need to do is add few wires.
Also, you can run the motor with EJ18 ECU. It wont drive well or boost but at least engine starts up and you can move the car.
If you go with 02 WRX ECU, you need to work on the harness to make it work and much much much harder.
My car is 94 with EJ18, I swapped it with 99 JDM EJ20 and running on Apex ECU.
I can certainly tell that the wiring was a biggest pain in the ***.
Yours should be easier because the year of motor and the car matches. Its a big difference.
Old Mar 9, 2004 | 06:27 PM
mrmodex's Avatar
i already have an apexi afc so i need to get boost controller and stuff right
also where can i get that ecu
lokdown00
Apr 17, 2014 09:49 AM
bringndefinitio
Mar 14, 2006 05:38 PM
DLN84
Jul 30, 2005 10:41 AM
bwendelburg
Aug 18, 2004 03:51 PM
GottaREX
Wanted
Feb 22, 2004 07:13 PM
