why no cel with a godspeed dp and all other u get 1
Old Aug 26, 2003 | 11:07 AM
illmatic's Avatar
You shouldn't get a CEL with the PDE as there is a physical fix and so does the godspeed dp. I think where the O2 sensor screws in there is a mesh type metal to simulate a cat.
jay
Old Aug 26, 2003 | 11:09 AM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Godspeed and PDE both have ways of circumventing the CEL light.
In the case of Godspeeds's pipe, it has a small piece of catalytic convertor material in there around the sensor IIRC. That is enough to not throw the CEL.
The PDE removes the sensor from the mainstream exhaust flow and only gives it s a fraction of the exhaust sampling. Thus no CEL.
Others just put the sensor in plain view of the exhaust gasses.
Old Aug 28, 2003 | 06:52 AM
ride5000's Avatar
no, it would not.
the p0420 code gets thrown when the ECU determines that the front and rear O2 sensors are "tracking" each other. with a properly functioning cat, the rear O2 sensor would be an integrated function of the output of the front sensor. in other words, it would appear very "smoothed out." in essense, the cat achieves this effect by acting like a storage resevoir for the ingredients of combustion, taking some out here, and adding it back there. the net result is cleaner emissions.
by using a small piece of cat material in between the exhaust gasses and the O2 sensor, the pipe makes the sensor react in the same way it would were the cat in the entirety of the exhaust flow, sidestepping the p0420 code.
it should be noted that the ECU will "test" for the p0420 code only once certain criteria are met. for example, coolant temps must rise by 40 degrees C, a certain amount of time must be spend motoring under 40mph, then above 60, etc. if these criteria are met, then the ECU calls it a "trip." this is why codes seem to "appear" at random--the cats are only tested during a trip. if you only drive 5 minutes to work every day and you keep it under 40 mph you will NEVER trigger a p0420 code!
hth
ken
LICmotorsports
Nov 27, 2013 03:30 PM
mylosti
Jun 23, 2004 11:47 PM
jonruhga04sti
Mar 19, 2004 09:34 AM
SilverRexxx
Aug 17, 2003 06:54 PM
