why is my car slower
Old May 11, 2004 | 11:11 PM
escaflowne's Avatar
Car Info: 2004 Black WRX wagon
different track conditions?
were your launches consistent?
Old May 11, 2004 | 11:31 PM
psychobooe's Avatar
Some form of engine management is really needed to utililize the free-flowing exhaust. I highly recommend the Cobb AccessPORT. I had a full catless setup for a few weeks while I was waiting for my AccessPORT. The car was faster for sure, but once I got the AccessPORT it was WAY faster. The programming takes advantage of the catless setup. Get the AP and you'll be all grins.
psycho
Old May 11, 2004 | 11:35 PM
Choku Dori's Avatar
Car Info: Corvette Z51
You might want to reset your ECU in the meantime. Your car's onboard computer probably doesn't know WTH is going on with all these new mods all at once, so reset it by unplugging the negative battery terminal for a minute or two, depressing the brake pedal a few times, then plugging the battery back in. You'll know it's reset when you lose all your radio station pre-sets.
Old May 11, 2004 | 11:43 PM
psychobooe's Avatar
Then go here www.cobbtuning.com and order the AccessPORT. It'll probably take 6 weeks to get it because of the backorder, but it's worth it. Trust me, you'll love it.
Old May 11, 2004 | 11:51 PM
Choku Dori's Avatar
steedsta, you want a quiet exhaust? I'll trade my stock catback
But anyway, this is a strange situation... I'd like to see how it resolves itself...
Old May 11, 2004 | 11:54 PM
psychobooe's Avatar
Choku's onto something with the ECU not knowing what the he!! is going on. The stock WRX ECU is smart, but not smart enough to compensate for a catless setup. I know that when mine was catless before the AP, it was a little faster, but mainly just a **** load louder. Engine management is the only way, plus it makes reliable power. I'm sorry that I can't help you about the turbo timer issue. I never bothered researching those.
Old Jan 18, 2005 | 06:15 PM
dubRexer's Avatar
Car Info: white/gold sti
Cool laggy lag
if you're runnin a stock turbo with your up/down pipe combo it's probably fu*ked with your compression with the turbo. probably makin the turbo work harder and producing worse results. solution = bigger turbo and getta tune esp.
peace!
Old Jan 18, 2005 | 07:12 PM
Gleb83's Avatar
Car Info: 2002 Alpine White WRX
peace!
The idea of a more free flowing exhaust is your turbo "works less hard" , therefore resulting in faster spool up and more power.
Old Jan 19, 2005 | 12:09 AM
mbquarts's Avatar
Car Info: 03 MBP WRX
1.1 bar seems high for the stock ecu...thats about 16 psi. Do you have a mbc installed?
Old Jan 19, 2005 | 12:18 AM
peace!
You have a lot of reading to catch up on.
