Who has HKS SSQV?
My SSQV is having some problem. The pass few weeks, it has been less responsive. Yesterday, it just stops working. I’ve check all the vacuum hose, they are all properly attached with no leaks.
Anyone experienced similar problem? Could it be a clogged vacuum line filter?
Many thanks,
Many thanks,
Hmmmm, Ive had mine in for 8 monthes and no problem. Some areas I would check: first, the bypass hose that you had to put that silver plug in...is it still plugged and okay? Second, I would check the hoses and ensure they are not freyed, melted, or plugged. Third, check the tightening screw on top of the valve. Im not a mechanic but I did install mine myself so Im familiar with all the connections and the process. Do you have a boost gauge and have you noticed any unusual boost changes? If I had the problem I guess I would check every aspect of the installation for any error. If the source is not there, then I have no clue. Hope I could help. PM me if you have any other questions.
Ryan
Ryan
Have anyone with a HKS SSQV experienced any problem? I've purchased a SSQV with two other friends. Mine died back in Febuary. Today, one of my friends begin to have the same problem as I did.
I've replaced the SSQV with the stock BOV, and it work perfectly fine. Therefore I know it isn't a problem caused by vacuum hose being lose.
Any help would be great, thanks
adamsrs
Oct 10, 2004 12:39 PM
adamsrs
Aug 21, 2004 11:12 AM
