whats next to do?
Old Oct 9, 2003 | 09:59 PM
awns729's Avatar
Car Info: want a WRX
well usually people get a turbo, injectors, fuel rails/pump at the same time, and either get a M/EBC or proper tuning(UTEC/reflash) which is the proper way to go....i dont see the point in getting a bigger fuel pump with stock injectors/turbo...what i would do is get a UTEC now, then later buy a turbo, rails, pump, and injectors at the same time, which is probably the best way to go if you dont want to upgrade the turbo right away
oh and if you do want to upgrade something now and are definately going to get a turbo later then just get a UTEC because if you reflash the stock ecu, you'll have to reflash it again when you get the turbo installed to get your moneys worth
Old Oct 9, 2003 | 10:03 PM
my2003wrx's Avatar
This might be a newb question, but do you really need a FMIC if you only have the exhaust mods and an intake?
Old Oct 9, 2003 | 10:06 PM
awns729's Avatar
No, not necessary at all, a bigger TMIC is usually sufficient for under 320 chp. FMICs, i think, have a bit more lag.
Old Oct 9, 2003 | 10:09 PM
my2003wrx's Avatar
I'd agree with awns, get a BC and some sort of engine management. Get the turbo and fuel mods together and then get it tuned. Before the tune you won't run optimum. Good luck.
Old Oct 10, 2003 | 07:13 PM
Musto's Avatar
Car Info: Subaru Imprezza WRX
I would go with some kind of engine management (UTEC, reflash, etc...)
With the mods you have done you will see the most improvement from engine management.
tom peters
Nov 16, 2004 08:52 PM
VIBEELEVEN
Nov 1, 2004 02:43 PM
burmis1
Jun 11, 2003 07:16 PM
rich hill
May 2, 2003 08:15 AM
