what is the stock boost on an 04 wrx?
Old Feb 5, 2009 | 03:21 PM
garrlex's Avatar
Car Info: 2004 Subaru WRX
Exclamation what is the stock boost on an 04 wrx?
what is the stock boost on an 04 wrx? I am debating about the first power adder to buy. I am about to buy a 22mm rear swaybar and trying to figure out how much buying a boost controller would really gain me... i dont know even the stock rating... what psi converts to "bar" ? and how far i could turn up the boost without hurting anything.
Old Feb 5, 2009 | 05:03 PM
DemonPossessed's Avatar
Car Info: 05 wrx
I think you need to look into some engine management before you start swapping parts. you just need to do some research.
suspension mods would be great start...
Old Feb 5, 2009 | 05:17 PM
Car Info: 05 wrx
oh stock boost if about 13.5 psi
and you shouldn't turn up the boost without engine management or mods.
Old Feb 5, 2009 | 05:19 PM
if you add boost but not fuel and take away timing you will blow the motor
Old Feb 5, 2009 | 10:12 PM
subarooster's Avatar
Car Info: 2002 wrx
a boost controller is the last thing you want. you turn up your boost but not your fuel and then you run super lean n blow your motor. manual or electric doesn't matter it's just pumps more air and sprays regular amount of gas so it's really not a good idea. if you plan on getting it protuned then go for it.....but you wont need it obviously the tuner could do it himself. first power adder should definately be downpipe although the suspension would be fun esepecially with a nice set of sticky tires
freshrex
Aug 25, 2008 01:59 AM
yzercyber
Aug 12, 2005 03:42 PM
rebbaz
Jan 22, 2005 08:52 PM
ShokWaveRider
Feb 21, 2003 06:14 AM
XwrxX
Dec 17, 2002 07:14 AM
