what mods after uppipe/downpipe? (was: What else?)
Old Apr 9, 2009 | 11:55 AM
North Star's Avatar
Car Info: 04 Aspen White STi
With an up pipe and down pipe, you should be fine for normal driving. Your stock ECU will retard the timing if any knocking is detected to protect the engine.
I drove my 03 WRX for 4 years with no cats and a MBC with zero problems, with the exception of the CEL light when cruising in 5th. Basically, the car was running rich as I also had the Blitz ABOV.
Unless you have an upgraded turbo, there is no need for headers. An intake would be good for some minimal gains. But ultimately, getting the Cobb Access port will be the most beneficial. You will be able to get mods later and have the ability to update with the Cobb Access port. Plus you'll get better MPG's versus the stock ECU.
Old Apr 9, 2009 | 12:37 PM
DemonPossessed's Avatar
Car Info: 05 wrx
Its pretty bad when people start to relay bad advice. The OP said he has a 04 and you had an 03. 02 and 03 wrx can go with out em. But his 04 cannot.
Old Apr 9, 2009 | 12:39 PM
Monyg85's Avatar
Car Info: Subaru Impreza WRX 2004
Yea i mean i agree, i do need to research...and i have. I did mean protuned, but i just didnt know if i needed to buy the Cobb ap right away. Hmh i realize now after reading that i do. And thats the plan as soon as i get done with installing the tbe on my car. But since the Cobb ap is a bit heavy on the pocket im not sure when ill be able to purchase it, i didnt know that running a tbe would cause problems eventually.
Old Apr 9, 2009 | 01:17 PM
North Star's Avatar
Ahhh, I didn't know that the 04 ECU was that much different! My 05 wagon has pretty much the same set up, minus the cat deletes with zero issues. I'm just relaying personal experience with my Subies.
Old Apr 9, 2009 | 04:37 PM
Car Info: 05 wrx
so are you running around with no em?
if so i feel sorry for your car.
Old Apr 10, 2009 | 06:16 AM
Monyg85's Avatar
So Ive been looking around trying to find places that sell the cobb ap for less than $695 but i cant find anything lower than that. Any ideas on places to look, or way to get a cheaper one??
Old Apr 10, 2009 | 08:25 AM
Car Info: 05 wrx
if you dont mind buying one thats used, then you can search the classifieds.
Old Apr 10, 2009 | 05:43 PM
Monyg85's Avatar
Yea i wouldnt mind at all...ive been trying to search
Old Apr 10, 2009 | 05:53 PM
Redils16's Avatar
Car Info: '02 WRX
if you just keep looking they pop up for around 500 every once and a while so i would say just be patient
Old Apr 10, 2009 | 06:04 PM
Monyg85's Avatar
Thats true, im hoping it would...been checking ebay but still same.
Old Apr 10, 2009 | 07:58 PM
Monyg85's Avatar
I was also wondering....ive read that the ap since, reflashing the ecu basically, can clear out Check Engine Lights? is that true orr??...ive had my checkin engine light on since installing the uppipe and dp and cant seem to find out why?
Old Apr 10, 2009 | 08:42 PM
Car Info: 05 wrx
The acessport will suppress the codes related to your stage 2 mods when you flash to stage 2. but if and when you get other codes like over boost, misfire, evap etc due to other problems. The acessport can be used to read and clear them(but untill these types of problems are fixed they will come back).
Old Apr 10, 2009 | 08:46 PM
TurnWRX's Avatar
Clearing the code just erases the code, not the problem. It will still come back later on. The AP acts like an OBD reader.
Your CEL is most likely due to you eliminating the cats. You'll need a CEL fix for that.
I highly suggest u get an OBD reader from Kragens or whatnot, or buy the AP to pull the error codes and look them up.
Old Apr 10, 2009 | 08:47 PM
Monyg85's Avatar
I see, yea thats what ive read so far. Thats ok, i just need to know what the problem is and ill fix it... i do have emissions that i have to pass and i have to fix that cel...all the more reasons to get the cobb ap!!!
Old Apr 10, 2009 | 09:00 PM
TurnWRX's Avatar
I would use some caution if you're looking into buying a used AP. If the seller still has the software married onto his car, but sells u their AP without unmarrying it, the AP will be useless and u won't be able to use it. So I would stay away from any used EBay deal or a private party dealing unless it was in person and u were able to marry the AP to your car.
