What modifications are needed for an ihi vf30?
Old Jun 3, 2004 | 07:00 PM
RussB's Avatar
Car Info: $200,000 sports car
you have heard correctly. you could get away without the downpipe, but it's very worthwhile having it in. You might want to put the intake and blow off valve back to stock. if you do that, tuning it will be a breeze.
Old Jun 3, 2004 | 07:14 PM
Daredevil's Avatar
get rid of intake and what you have said is the truth, you need that stuff
Old Jun 4, 2004 | 12:07 PM
bone324's Avatar
Car Info: '02 WRX WRB
If you're going to go to all the trouble of buying and installing a bigger turbo you should at least do the upgrades you mention in order to maximize the gains from it. I'd also strongly recommend a new set of tires if you're still on the RE92s. They can't handle 227hp, let alone 300+. Sell the intake, BOV, and MBC.
Old Jun 4, 2004 | 02:28 PM
awns729's Avatar
Car Info: want a WRX
don't sell the BOV, with higher hp you might want that bov. but the MBC and intake should be sold for an ECU upgrade along w/ injectors, pump, rails, up, dp,
Old Jun 4, 2004 | 04:57 PM
bone324's Avatar
The IHI VF30 is the standard turbo on the JDM STi v7, which uses the same BOV as your stock WRX. You will not need an upgraded BOV for any IHI turbocharger.
Old Jun 5, 2004 | 01:37 PM
awns729's Avatar
But since he already has the BOV, what is the harm in keeping it?
Old Jun 5, 2004 | 04:11 PM
bone324's Avatar
Maybe no harm, except the normal running rich and stumbling depending on what type of BOV it is. Plus, with all the money he'll be spending on downpipe, uppipe, injectors, and ECU he could probably use the extra cash. I'm not saying that you can't run the turbo with the BOV and intake. I'm just saying that they might cause more harm than good.
Old Jun 5, 2004 | 07:50 PM
awns729's Avatar
I think intakes usually cause much more of a hassle than BOVs, unless its 100% atmospheric. And if he's getting it tuned, would running rich even be a problem?
Wrxplaya, what kind of BOV is it?
Old Jun 6, 2004 | 11:25 AM
awns729's Avatar
Its 100% atmospheric, you may want to ge ta 50/50 BOV instead.
Old Jun 7, 2004 | 07:50 PM
ride5000's Avatar
you sure about that?
haven77
Subaru OEM Parts For Sale
Mar 9, 2004 02:40 AM
Zoeb2s
Jan 10, 2004 12:18 AM
K3TR
Canada
Oct 9, 2003 06:05 PM
East Coast WRX
Sep 26, 2003 09:49 AM
K2Skier
Feb 17, 2003 05:47 PM
