what if my new boost guage doesn't point to zero??
Old Oct 23, 2003 | 10:29 PM
BoOm's Avatar
vaccum?
Old Oct 23, 2003 | 11:46 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
just make sure when you hit your NOS, that your boost doubles
Old Oct 24, 2003 | 12:17 AM
chyknees's Avatar
Car Info: 02 white WRX
I have a Subaru boost gauge and a Blitz SBC-ID and for me, When i'm driving, and its at 0.00 psi on my Blitz, it reads .1 on my boost gauge, so i dunno where which one is correct, but i go with my Blitz sbc-id.
Old Oct 24, 2003 | 12:56 AM
Daredevil's Avatar
scott, you've been all over the NAAASSS tonight, you gonna get a big bottle, no better make it 2
Old Oct 24, 2003 | 01:45 AM
international B's Avatar
Chewwwwy
autometers never point to zero... they suck, just snap the glass a few times, you might get lucky!!!
Old Oct 24, 2003 | 10:46 AM
ScoobyStas's Avatar
Car Info: Sonic Yellow WRX
When the car is on, it should be in vacuum around 500. My greddy shows zero when i turn the key to turn on the radio only and not the ignition.
Old Oct 25, 2003 | 02:33 AM
Uncle Scotty's Avatar
I had an Autometer boost guage do the same thing.
I took it back and got a new one, no questions asked.
Old Oct 26, 2003 | 11:17 AM
CFar's Avatar
Ive got a stock boost guage and it reads a bit under 0 when the car is off. Not sure what the deal is
Old Oct 26, 2003 | 06:23 PM
BoOm's Avatar
return it, if it wasn't connected then there is something completely wrong with the item.
Old Oct 28, 2003 | 03:24 PM
killaho's Avatar
UTR Member
Car Info: 93 Impreza L
same with mine... its at the very bottom of zero
Old Oct 28, 2003 | 04:00 PM
shawnshekari's Avatar
Zero bost gauge
The gauge is reading atmospheric pressure and was probably set to read zero at 29.92". (reflects standard atmospheric presure at sea level @ 59deg F)
If there is a weather system either increasing or reducing the atmospheric presure the gague will reflect that presure change. Also if you live at an altitude above or below sea level the presure will be higher or lower.
Make sense?
-Shawn
'02 WRX
www.shekari.org - Experimental aircraft construction images
Old Oct 28, 2003 | 07:48 PM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
Get new ones... it shouldn't be like that.
