What are the best ways to spend $1000 for HP gains?
Old Feb 23, 2003 | 10:17 AM
bone324's Avatar
Car Info: '02 WRX WRB
You will most likely not be able to buy an uppipe and turboback for under $1000. If you do let me know and I'll buy from there too. I would go with the uppipe and the TurboXS Stealthback. That should run right around $1000 excluding installation. Then, later on, you could buy an axleback to complete the turboback.
Old Feb 23, 2003 | 10:16 PM
Astacun1's Avatar
I am with cobraKLR on this one. I would buy the UTEC. That was my very first mod also. I was aso limited to aprox $1000, but after the UTEC I just wanted more and more and more....so I added a turboback and an uppipe and gauges. I am very satisfied but I want more...I think this is what has happened to all of us, once you start modifying your car it's addictive, you just can't wait to spend that extra money in your rex.
Astacun
Old Feb 28, 2003 | 08:57 PM
BlueGargantua's Avatar
Your priorities are different than mine I spent my first two thousand on wheels tires and suspension.
you could get an uppipe and a ECU re-flash which should be good! However, I am assuming that you might want more mods later and another 175 per reflash is not so appealing.
So plan B: uppipe and save a bit more $$ and do the turbo back, Then you can enjoy that.......
