Wastegate Problem??
Old Nov 4, 2004 | 10:22 AM
SilverRex04's Avatar
Car Info: 04 Sti swap, VF22 18psi, 255l fule pump,ecutek 93 oct, Full exhaust TXS, Sti ra gears, much more...
Question Wastegate Problem??
Hi, I have an 04 wrx, right now its back to stock because i was having problems. I used to have mbc, cai and bov now its back to stock but im still having the same problem. The problem is when i get hard on the gas or get to about 5000 rpm the car sputters, hesitates and sounds like detonation? Then the boost will spike at 20psi and sputter up and down between 20psi and 10psi. I was told it could be a wastegate problem? I really need your guys help im new to the turbo world. Thanks. Tom
Old Nov 4, 2004 | 10:25 AM
Oh and another thing the car only has 10,000 miles on it.
Old Nov 4, 2004 | 11:52 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
first of all, don't drive it if its spiking to 20psi. What did you put on the car before it started doing this? Are you sure you installed all the stock hoses propperly?
-- Ed
Old Nov 5, 2004 | 02:22 AM
ilivas's Avatar
sounds like a wastegate acutator hose missing or damaged.
Old Nov 5, 2004 | 08:22 AM
The car had an AEM cold air intake, Turbo xs MBC, and Turbo xs BOV. I think the hoses are proper the restrictor is going to the wastegate, and the non-restricted part of the "T" goes to the stock boost controller etc. Thanks for your help guys im going to work on the car some more now ill let you know if i get anywhere. Tom
Old Nov 5, 2004 | 09:42 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
I think that's your problem.... The hose with the restrictor pill inside needs to be comming off the compressor housing nipple I believe.
-- Ed
Old Nov 5, 2004 | 10:15 AM
Hey Ed, What do you mean by "pill inside" I have a little white "T" that has two big hole and one small. Is that what you mean, or am I using the wrong "T". Thanks again. Tom
Old Nov 5, 2004 | 02:54 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
No, I'm talking about the piece of hose that has a little metal restrictor inside. You can feel it with your fingers. This hose needs to go on the compressor side barb.
-- Ed
nallen316s
Oct 6, 2014 11:54 AM
hey1230000
May 19, 2010 07:27 PM
scby blu
Jan 14, 2008 09:37 PM
xs_wrx
Feb 27, 2006 06:27 PM
sjice
Dec 31, 2005 01:15 AM
Top
