vishnu upp or helix upp?
Old Jun 12, 2004 | 04:57 PM
hezlok's Avatar
Car Info: basically stock wrx
Angry vishnu upp or helix upp?
i've decided to put an uppipe on my car, but which do you people prefer, my setup is that im going to get vishnu pulleys with helix downpipe and planning to get the accessport, what will mate good with this.... vishnu or helix uppipe?!
Old Jun 12, 2004 | 07:29 PM
Needles's Avatar
Car Info: 2002 WRB WRX
A pipe is a pipe.Save the money and go with Helix.It matters how you install it,not what company you buy it from.Or better yet save alot of money and gut your stock pipe,if you have the time.
Old Jun 12, 2004 | 09:00 PM
chicote's Avatar
Car Info: 02 wrx wagon
Gut your up pipe if you have time and think its worth the effort. if you are already going to get the Helix dp then go ahead and get the helix up pipe together you can get them for 450 from gruppe-s its a good deal and that price is shipped to your door. I've got the helix up and down and I'm very pleased! I wouldn't spend the extra money on the vishnu pipe. With the accesport you'll be smoking i'm sure! Have fun!
Old Jun 12, 2004 | 10:31 PM
escaflowne's Avatar
Car Info: 2004 Black WRX wagon
just get the helix. VIshnu is better in that it has a better build. The difference is nugatory.
Old Jun 13, 2004 | 12:55 AM
hezlok's Avatar
thanks for the help, ill be saving lots of money
Old Jun 13, 2004 | 02:24 AM
Littleboyblue's Avatar
I wouldnt gut the up pipe. The problem is if you need to get it smogged, you won't pass smog without that up pipe. The cat in the up pipe is there to help the car heat up during the smog. I would go with the helix and keep the stock one for the smog days.
Old Jun 13, 2004 | 01:06 PM
knight1833's Avatar
Car Info: 98/05 RSTi
make sure it's a flex pipe, it's helped mine spool much quicker
Old Jun 13, 2004 | 04:14 PM
Lurk's Avatar
Wouldn't it be easier to just swap the stock downpipe in for smog? I would think it's better too, since it has two large cats in it.
Old Jun 13, 2004 | 04:47 PM
bassplayrr's Avatar
You can usually pass the sniffer part of the smog test just fine with a catless UP so long as you reinstall a catted DP. The cat in the UP is only there for start up emmissions because it heats up so wuickly that close to the manifold. However, if you simply drive the car for a few minutes before the test and get to operating temp the DP cats will be sufficiently warm to pass. The visual is another matter, though most smog shops don't know where to look for the UP anyway.
-Chris
Old Jun 13, 2004 | 07:29 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
BS!! Have you seen the stock uppipe cat? It's for COLD START emissions only. There is no way in hell you'll fail smog without it.
Old Jun 14, 2004 | 01:25 PM
gruppe-s's Avatar
www.gruppe-s.com
we have the Helix ones instock!
seeya!
Old Jun 14, 2004 | 01:26 PM
nic3krnnamja83's Avatar
helix is always nice
Old Jun 14, 2004 | 06:48 PM
Blarg's Avatar
if you're worried about passing smog either get the STi pipe (looks EXACTLY like OEM but catless) or PDE. The PDE pipe lets you put all the heat shields back on (others don't) so unless someone's REALLY REALLY looking hard, noone will notice it.
Old Jun 15, 2004 | 08:21 PM
downshiftdan's Avatar
Car Info: 2003 WRX Sedan
if you are trying to save money gut your stocker...if you are trying to get the best pipe out there check out the Crucial Racing Systems pipe--perfect fit, 321 like the vishnu and ceramic coated for $250
Old Jun 16, 2004 | 01:56 AM
hezlok's Avatar
do you guys know if the uppipe will make my exhaust much louder? my turbo spool louder? i kinda wanna go quiet
