VF-34 Question
Old Jan 31, 2006 | 07:49 PM
JEDI's Avatar
Car Info: EJ20T, CGM 2005
Question VF-34 Question
I have a VF-34 Turbo only. Can I install that the turbo without the injectors, fuel pump and tuning? Or will it mess things up? I'm planning to get the whole setup soon. Just excited to put it on. Or Should I Wait? Thanks.
-Jedi
Helix up & down, STI TMIC, Cusco Front & Rear Strut bars, TEIN S. TECHS, HKS Hi-Power Exhaust, HKS Super Mega Flow Intake, Apex-i turbo timer.
Old Jan 31, 2006 | 08:00 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
You can, but you should run in on spring pressure (8-10psi)
Old Jan 31, 2006 | 08:03 PM
JEDI's Avatar
please break it down for me =) What do you mean by "Spring Pressure"
- Jedi
Old Jan 31, 2006 | 08:24 PM
Imprezer's Avatar
Admin v2.0
You cannot just bolt it on. It flows a lot more air and even at same boost levels your car will run dangerously lean. You remove the vaccum hoses from it (and remember how they go so that you can put it back later on) and connect the wastegate nipple to the compressor nipple. That way you will run 8-10psi which is wastegate pressure.
Old Jan 31, 2006 | 08:27 PM
JEDI's Avatar
Thank you so much!
- Jedi
brucelee
Aug 1, 2009 10:59 AM
legacy2003
Jun 8, 2003 04:43 AM
