US vs. JDM STi tmic??
Old Jan 4, 2004 | 03:24 PM
DWNSHFT's Avatar
Car Info: 03 sedan 2nd wrx
Question US vs. JDM STi tmic??
What is the diffrence of these two which is better for wrx swap and how can you tell jdm from us?
thanks
Old Jan 4, 2004 | 04:58 PM
international B's Avatar
Chewwwwy
jdm sti intercooler is larger. it will mount to the outside hole on the bracket above the turbo. i would say go with the jdm one.
Old Jan 4, 2004 | 08:49 PM
Zoeb2s's Avatar
I <3 White Girls
I heard minor modifications are needed for the US on. From what I heard the JDM one is a straight bolt on.
-Zoeb
Old Jan 4, 2004 | 09:47 PM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
I believe the JDM unit is 40% bigger than the USDM WRX and 14% bigger than the USDM STI.
Mike
(510) 487-4447
www.mpjperformance.com
www.gb-motorsports.com
Old Jan 5, 2004 | 01:06 AM
DWNSHFT's Avatar
Mike
(510) 487-4447
When will you guys be getting a jdm one in stock
Old Jan 5, 2004 | 09:09 AM
Former Sponsor
We have a used one available right now, $475 with Y pipe and so on.
Mike
(510) 487-4447
Old Jan 5, 2004 | 10:05 AM
Uncle Scotty's Avatar
If you install a JDM STi TMIC, make sure to check for clearance---lack of, that is, at the firewall. The A/C lines may(will) have to be bent/re-routed/padded in order to prevent damage to them.
Be sure to look at where the inlet ducts may rub and not just the endtank. I had the small A/C line on the drivers side rub through at the inlet duct, and the large line on the passengers side above the service valve needed to be heavily padded to prevent damage.
I would also strongly recomend an STi hoodscoop and an STi splitter.
I got a Ver.7 STi RA Spec C Air Splitter & Intercooler Seal Kit, which is a VERY lightweight aluminum splitter from rallispec.
Perfect fit and the splitter/seal weighs 1.5 pounds MAX.
I had a GT-Spec splitter and it was stainless steel and weighed at least 10 pounds....probably more.
Old Jan 5, 2004 | 01:30 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
my usdm sti intercooler fit perfectly in my wrx
Old Jan 5, 2004 | 07:21 PM
The JDM IC fits perfectly...the A/C lines just interfere with it.
Old Jan 5, 2004 | 07:50 PM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
but if there was interference, would it really be fitting perfectly?
(i'm kidding)
Old Jan 5, 2004 | 09:06 PM
DWNSHFT's Avatar
Mike is this true? And how much would you guy charge to get it done at the shop so that it stays under warranty?
Old Jan 5, 2004 | 10:37 PM
Former Sponsor
What warranty?
Mike
(510) 487-4447
Old Jan 5, 2004 | 11:39 PM
DWNSHFT's Avatar
as in if the lines are broken due to rubbing on ic
Or is the above something that I shouldn't worry myself with?
Old Jan 5, 2004 | 11:59 PM
Former Sponsor
Never known it to be a issues, you move the AC lines like you would for a Cusco bar.
Mike
(510) 487-4447
Old Jan 6, 2004 | 08:30 AM
Wingless Wonder's Avatar
Miguel, it sounds like you are leaning towards the JDM piece but someone is selling a used USDM STi intercooler with y-piping and OEM BOV for $375 in the For Sale By Members forum.
