Uppipe Question
Old Feb 6, 2003 | 11:04 AM
mmboost's Avatar
BTW - I don't think there's an "STi catless uppipe" for $150. If you're talking about the one's like I-Speed got on super-mega-backorder its the WRX JDM, not STi. I could always be wrong, but I believe this is the case.
jason
Old Feb 6, 2003 | 04:23 PM
Sea Dragon Rex's Avatar
Car Info: 02 WRB Wagon (Cobb AccessPort, P7's), 2-73 914 2.0, 74 914-2.0
I'm in the same boat. You don't want to gut a stock uppipe. If you are going to spend the time and/or money to change the uppipe, buy one that is already catless. Either the JDM WRX catless or one of the aftermarkets. Thanks for the info Jason. Didn't know that. I set on getting one of the I-speed pipes (yeah, I'm on that long waiting list). Now if they could only get that shipment so I can make the change before the exhaust nuts lock up permanently.
Old Feb 6, 2003 | 04:44 PM
RogersWRX's Avatar
Car Info: 2002 White WRX Wagon
I have a gutted stock up-pipe, and like the fact that it's subaru quality, has the flex section, heat shields, is definitely gonna fit with no exhaust leaks and looks totally stock to the dealer! Plus, you can't beat the price!!
And yes, I definitely notice the improvment in smoother spool up and low end torque!! Although it seemed more noticable after a couple of days of driving around with it in. I don't know if the ECU had any leaning to do with the increase air flow!
Old Feb 6, 2003 | 07:27 PM
BlueGargantua's Avatar
Lightbulb
subaruwrxparts.com has a couple of flex joint BPM upipes left as of this hour for 225.00 each. I have one on its way ,,,,,,yipppeee
Old Feb 6, 2003 | 09:29 PM
RogersWRX's Avatar
What some people don't seem to understand, when they order larger diameter up-pipes, is that you want air VELOCITY, not VOLUME. Larger diameter pipes flow more air, but at a slower speed. Narrower pipes force the air to increase in speed and density.
The faster you can get the air flowing, the quicker it spools the turbo. The narrower aperture where the cat used to be is designed to speed up air through the cat and keep the turbo spinning. It works the same way without the cat.
After the turbo (especially with a larger turbo) you want to evacuate a larger VOLUME of air to reduce back pressure against the turbo, that is why larger pipe is often used back there.
Old Feb 7, 2003 | 08:47 AM
I'm not sure about this but here goes. Part of what you says makes sense. By going to a narrower uppipe, the air density will increase and since you have the same amount of air going through a smaller diameter, air speed should increase also which is good for faster turbo spool-up.
But, there is a negative aspect to this. If you go from a wider opening to a smaller one, you are also creating a restriction prior to that narrow section which would create backpressure and thus hinder evacuation of gasses from the combustion chamber. So, I would think it is a balance. Of course, with the cat in place, there is plenty of restriction and loss of air velocity.
Old Feb 16, 2003 | 02:38 AM
DriftinS14's Avatar
Car Info: 02 WRX, 06 A3
Arrow
How much hp can I expect to gain with adding a nice after market uppipe? What are the pros and cons of an uppipe with or WITHOUT a flex section. I noticed some of them are solid. Which would you guys reccommend?
Thanks!
Old Feb 17, 2003 | 07:31 PM
fastnoypi's Avatar
Re: Re: Uppipe Question
Originally posted by BlueDemon
I went with the PDE uppipe. But in reality, almost all uppipe are the same. The TurboXS is made of Cast Iron, so it will rust a lot faster than say the Perrin. But it's thick, and it won't rust through for years.
Blue
Cast Iron wont make an uppipe "faster" ..its just a better quality metal to work with right after the header. I can handle the heat cycles much better.
