Uppipe install help
Old Aug 12, 2003 | 12:53 PM
EWThompson13's Avatar
1 to 1.5 hours is definitely for a professional with all of the right tools, a lift, and a bunch of previous pipe installs. I personally just did this mod last Saturday, and spent a total of 6 hours for the complete install. I am very good with tools, but the first time you do anything, it always takes a while. The pipe will slide right out if you loosen the pasenger's side motor mount, and very CAREFULLY, jack the motor up about two inches using a block of wood on the oil pan. This mod is sooooo worth it though. Very good turbo spool up and there are good hp gains.
ERIC
Old Aug 12, 2003 | 01:55 PM
Scoobymods.com
I used the instructions for a Perrin up-pipe install that I found at scoobymods.com. There are many more pictures here than the Turbo XS ones. I think it is always easier with a good visual especially when it comes to putting something back together.
http://scoobymods.com/forums/showthr...p+Pipe+Install
ERIC
Old Aug 13, 2003 | 10:11 PM
WyldKardzWRX's Avatar
Car Info: 2002 Aspen White Wrx Wagon
i also used scoobymods.com. the first time i did the install it took me a good 7 hours. my advice to you is to make sure that you lube those nuts and bolts that connect the up and the down pipe to the turbo. this will prevent you from working as hard as you would w/out lubing. one time i did 4 uppipes in one day.
pete
Old Aug 19, 2003 | 05:01 PM
Dick Fitzwell's Avatar
vishnu tuning
shiv's instructions are so simple to go by, you could train monkeys to do uppipe installs!
i also agree, the 1-1.5 install is just not feasible for a DIY'er. unless of course you have installed a few already, have a lift, all the tools on hand and maybe even an extra set of hands to pass you tools and whatnot
first time i did mine, it took me ~five hours by myself. alot of getting up on top of the car, then underneath, etc. an extra set of hands and two shop lights would help out a ton....oh, and get some ratchet wrenches and an offset o2 sensor socket (short)
good luck
Ibobby dI
Mar 7, 2004 03:12 PM
DOHCammin
Aug 8, 2003 05:48 PM
Wagon Joe
Rocky Mountains
Jul 16, 2003 10:36 AM
spdkills
Jan 29, 2003 03:36 PM
