uppipe/downpipe installed.... BIG PROBLEMS
Old Dec 29, 2003 | 11:15 PM
jpsimon's Avatar
Ok so i installed a vishnu uppipe and helix downpipe (which includes midpipe)...
everything went smoothly... everything was working fine, i took a drive to get gas earlier today and everything was a ok.... later today i went to start my car and the exhaust was 3 or 4x as loud as it should be.... a really rasspy.... bad sound... and when i went to drive the max boost it would reach was around 10psi... at most.
would this be some kind of upipe/downpipe leak causing these loud loud noises and lack of boost?
also... no CEL has come up yet... i didn't do the cel fix on the downpipe.. and i assumed i would get one....
now, ive been reading that if its an uppipe leak it would be a high pitched screeching noise.
My noise is NOTHING like that. The sound kicks in when i press on the gas... at ANY RPM in ANY gear. It is a really really loud raspy thumpy noise...
Old Dec 29, 2003 | 11:23 PM
tide's Avatar
Car Info: 2006 Spec.B
sounds like a downpipe leak perhaps... did you use all new gaskets on the install? You need to make sure to get all 5 bolts (including the pesky one under the turbo) on the downpipe. I had a bit of leak when I first put everything one, so I threw it back up and hit every bolt a second time. Also, if you took the intercooler off, double check all the vacuum lines.
Old Dec 29, 2003 | 11:26 PM
ScoobyBoy's Avatar
ditto...check all the hoses, and maybe try an ecu reset.
Old Dec 29, 2003 | 11:35 PM
jpsimon's Avatar
i was just told it sounds like the EGT probe came out of the uppipe, i hope this is what happened, as this is a 10 second fix...
i need to get home so i can check this out!! ahh
Old Dec 29, 2003 | 11:37 PM
tide's Avatar
Yeah that could be it too. Let us know for future generations!
Old Dec 29, 2003 | 11:48 PM
jpsimon's Avatar
ill keep ya updated!
Old Dec 29, 2003 | 11:56 PM
It's either the EGT probe coming out (I saw this happen on the Vishnu stage III production car- it was cool) or an uppipe leak, which is way NOT cool. You'll know for sure once you check out the EGT.
Old Dec 29, 2003 | 11:59 PM
Daredevil's Avatar
im hoping its just the egt gauge !
Old Dec 30, 2003 | 12:47 AM
international B's Avatar
Chewwwwy
check the egt probe like everyone else said. ALSO check the 02 sensor in the downpipe.
Old Dec 30, 2003 | 01:45 AM
porkchop's Avatar
Car Info: some silver thing
if you're only getting 10 PSI, it'll be in the uppipe, you won't lose boost if it's a leak in the DP.
Just plug up the EGT probe with a bolt and use a 2.2k ohm resistor. You can tighten the EGT probe as much as you want, but sooner or later, the pulses from the exhaust will walk the probe back out.
Tommy
www.mpjperformance.com
Old Dec 30, 2003 | 06:25 AM
ride5000's Avatar
i must be really lucky, then--going on 10k miles with that probe not budging an iota.
ken
Old Dec 30, 2003 | 11:12 AM
porkchop's Avatar
ken
What used to happen to some of the cars we have seen is that, after they use launch control(UTEC), the probe will be loose.
of course, these are just certain special incidences that we have seen. =)
Tommy
Old Dec 30, 2003 | 11:50 AM
ride5000's Avatar
ahh... that dastardly launch control strikes again!!!
it seems using that takes quite a toll on your mechanicals. too bad... i'm sure it's a rush!
ken
Old Dec 30, 2003 | 12:47 PM
jpsimon's Avatar
so has anyone else had a "loud helicopter sound coming from the right passenger side of the engine bay" ? if so what turned out to be your problem?
Old Dec 30, 2003 | 01:19 PM
tide's Avatar
What did you replace?
