Upgrading turbocharger, questions
Old Nov 10, 2003 | 06:22 PM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
nope, it sounds like you know what you need. i think most people making 300hp are running either VF22s or PE/AVO turbos.
Old Nov 10, 2003 | 08:10 PM
yeah, gauges wouldn't be a bad idea at that point. i can't comment much on the vf22, sice i don't have one, nor have i ridden in a car with one. i have heard that they don't spool until relatively high rpms. then again, most turbos big enough to support 300+ at the wheels are pretty damn big, and take some time to spool. if you go with a vf22, talk to the fine folks at Deadbolt, they port turbos to make them spool faster.
Old Nov 10, 2003 | 09:46 PM
international B's Avatar
Chewwwwy
stock tranny i wouldnt count on. ihi route you will need a vf22, otherewize you will prolly need a pe1820.
Old Nov 10, 2003 | 10:33 PM
some people shred gears with stock hp, others are making 280 @ the crank and not breaking gears. it kinda depends on how you drive, and how lucky you got with your tranny. with 300hp, i'd count on replacing it sooner rather than later though.
Old Nov 10, 2003 | 11:15 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
your playing russian roulette with the stock tranny.. it may last, but like muppet said, people with stock horsepower broke them too
if you really wanna be reliable, plan to plop down the 6k for a STi tranny
Old Nov 11, 2003 | 05:34 AM
hotrod's Avatar
driver not power
There are some people that have over 150 drag strip passes and 400+ hp using a 50 shot of N2O, that are still on the orginal tranny. If you don't abuse it you will probably be okay at that power level.
A 100 shot of N2O will shell low gear in the blink of an eye.
The tranny is not weak, so much as it has limited ability to survive major mistakes.
You will only get away with a couple of bad mistakes.
Larry
