Up-pipe questions
Old Jan 2, 2003 | 09:10 PM
areg's Avatar
Car Info: 04 STi/67 rotary 311/C20/DT Barracuda
up-pipes
I haven’t run into anyone who has gotten a cel from installing a up-pipe...unless that up-pipe did not have a bung for the egt.... most up-pipes have a egt bung and the ones that do not usually supply a resistor to compensate and thus no cell. Currently I have a Vishnu up-pipe no leaks no problems...lot of up-pipes on the market so you have a wide choice of manufactures. Personally I am not a fan of the flex joint but if were to get a pipe with one... I would go with the APS up-pipe that has a built in flex...
areg
Old Jan 3, 2003 | 01:55 AM
IS2Scooby's Avatar
Pr0n King
Car Info: Turncoat Turbo
Got a p0546 from my PDE uppipe (that has an EGT bung). Did the 2.2k ohm resistor mod and I'm down the road motors... No problems after that!
__________________
Old Jan 3, 2003 | 06:08 AM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
Thumbs up
A lot of us use the P.D.E up-pipe in hawaii and haven't had any problems yet.
Old Jan 3, 2003 | 09:55 AM
Rexstang's Avatar
First 12sec WRX in HI
Car Info: 12.93@106.71
Vishnu unit is very well constructed, however PDE is just as good, no problems whatsoever yet. (fingers crossed).
Old Jun 14, 2003 | 09:29 AM
RogersWRX's Avatar
Car Info: 2002 White WRX Wagon
Just got the P0546 (High Voltage / Low Temp) CEL, on my stock gutted up-pipe. I've had it in for about 8k with no problems, the car is an 02 WRX Wagon with about 14k on it.
Took it to the dealer and they replaced the EGT probe under warranty. I didn't mention that the up-pipe was gutted though... Apparently the EGT Probe goes bad with a lot of stock up-pipes also!!
