up pipe
Old Jan 29, 2006 | 09:32 AM
scubaru8's Avatar
up pipe
how do you no if an up pipe is shot
Old Jan 31, 2006 | 07:39 AM
Egan's Avatar
Do you mean the stock uppipe? The only thing on a stock uppipe that could possibly be "shot" would be the catalytic converter. If it clogged up or something along those lines, you would have significantly reduced power and boost. There is also an EGT sensor in the upper section of the stock uppipe, after the cat, which can fail. If it does, it will generate a check engine light.
Old Jan 31, 2006 | 08:16 AM
scubaru8's Avatar
nvm solved the problem
vsick
May 16, 2011 02:26 PM
fliped wrx
SoCal Classifieds
Jun 8, 2007 10:52 PM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
bluesube
Dec 9, 2002 07:34 AM
