TXS Wastegate?
TXS Wastegate?
I was reading recently in a import tuning magazine about the WRX's problem of boost dropping off after 5k RPM, my wrx has this problem also, and if you replace the stock wastegate with a turboxs one it will hold boost pressure until redline. They also uped it to 16 psi while they were at it, has anyone had any experiences with the mod? Is it safe? and how will it affect my 100,000 mile warranty.
Car Info: $200,000 sports car
your wrx drops boost after 5k rpm because it's programmed to do that. simply upping the boost through mechanical mods without altering engine management can cause problems in the long run. and as for your warranty, you will probably be denied any claim that relates to the engine / drivetrain if you do this mod.
Stock wastegate with a turboxs one? Are you sure you are using the correct term? Maybe boost controller?
Last time I checked, TXS Doesn't have a wastegate product.. at least from what their site says.
Anywho; On my stock WRX, err rather.. when the stock motor was in. I ran ~ 21psi. The motor let go due to fueling issues after a while. So the rebuilt motor that I have in there now is quite nice. Basically same thing. Only everything is forged and the cylinders are sleeved. Running at 19psi, I now have 59,000 miles on it, without a hitch, knock on wood.
If I were you, on a stock turbo. It really begins to lose its efficiency around 17psi. So keep it at 16 if you are going to 'up' it. Honestly I suggest before even doing something as small as that. Go buy a used utec or unichip. Get some engine management going first.. then some fueling. Then start messing with boost.
Just my two cents.
-G
P.S. Most dealers, do not accept mods at all. Most dealerships will not service modified cars, you are lucky if you find one that does. My dealership looked at my like I was nuts when I asked for an oil change.. and all I have is a stage 4 with a FMIC and catch can. and some other little goods.. I guess they got confused when they saw the nitrous bosses...
Just my two cents.
-G
Car Info: Joe P MBC, Walbro 255 fuel Pump, Cold Air Intake,Apexi Turbo Timer, HKS Downpipe, Apexi Cat Back,BOV
External Wastegate
I have a Tial External wastegate and i noticed a bit more power when i first put it on but now im just used to it...
That was on the stock turbo now i upgraded to the 18g so once again i welded the door shut and am gona be having a blast soon cause i get tuned on tuesday...Booyah!
By the way it sounds incredible no wrx has that sound as soon as it opens up like mine
its not alot
you spend like 200 bucks on wastegate and then get it welded to the uppipe and get the flapper door welded shut maybe 300 bucks
nallen316s
Oct 6, 2014 11:54 AM
hey1230000
May 19, 2010 07:27 PM
scby blu
Jan 14, 2008 09:37 PM
xs_wrx
Feb 27, 2006 06:27 PM
