Turbo Timer not doing it's job.
Old Apr 19, 2007 | 06:57 PM
Felton Local's Avatar
Car Info: 2003 wrx
so i just finished putting in my new hks type 1 turbo timer into my 2003 wrx, the timer itself works as it is supposed to as far as i know. i went for a little drive to get the car warmed up and put some seconds on the timer when i shut my car off it only stayed running for like 1 second. i drove around for a bit more and tried again and the same thing happened, i got the timer up to about 50 seconds thinking that should be enough everytime.
did i possible hook something up wrong? has this happened to anyone else? im confused as to what is going on with it.
Old Apr 19, 2007 | 07:16 PM
ipozestu's Avatar
Car Info: Broken Subarus
Do you use your emergency brake? Did you hook the wire up to the emergency brake switch?
Old Apr 19, 2007 | 07:49 PM
Car Info: 2003 wrx
yes and yes, i even tried without the e-brake.
Old Apr 19, 2007 | 08:57 PM
strider327's Avatar
Car Info: 2005 WRX
Check wires and reset the turbo timer.
Old Apr 20, 2007 | 12:37 PM
Car Info: 2003 wrx
is it possible that i got directions for a different year? i remember getting confused because i had two sets of directions and wire colors were different on them. the e-brake wire i spliced with was red (not pink), the RPM wire (brown from the turbo timer), i spliced with the (green) wire in the ecu, and the blue (SPEED) wire that (according to my directions) was suppose to plug into the ECU was connected to the part of the harness that plugs in underneath the steering column.
Old Apr 20, 2007 | 12:46 PM
caseysrex's Avatar
Car Info: 03' WRX
you want to make sure the wires are grounded to metal in your car. in my trubo timer, blitz, I didnt hook up my parking brake and didnt ground the wire that went to my parking brake and everything worked fine except it didnt keep running when i shut the car off. Then i grounded that wire and it worked perfectly. hope that helps
Old Apr 20, 2007 | 12:51 PM
Car Info: 2003 wrx
does it have to be grounded to somewhere that is constantly getting power? or does that not matter?
Old Apr 20, 2007 | 01:04 PM
SubyN00by's Avatar
it should be grounded to bare metal that has no power on it. ie chassis, engine block, etc.
Old Apr 20, 2007 | 01:22 PM
Car Info: 2003 wrx
well im positive i have a good ground i just went and tore apart the steering column and re-grounded it twice and its still shutting off right after i pull the key out.
Old Apr 20, 2007 | 05:52 PM
strider327's Avatar
Car Info: 2005 WRX
Well if you got the wires right and the ground is good. Just try resetting it. It wouldn't hurt to just try that.
Old Apr 20, 2007 | 07:02 PM
Car Info: 2003 wrx
i tried ressetting it and playing around with all the other features (0-60, RPM gauge, etc...) but none of that seemed to work either.
Old Apr 20, 2007 | 08:05 PM
03_Impreza_Al's Avatar
Shouldn't have to tear apart the steering column.
Did you buy the harness to plug it to the car or did you splice into wires?
Old Apr 21, 2007 | 11:44 AM
Car Info: 2003 wrx
i have the harness but i still had to splice into the e-brake wire and the RPM wire coming out of the ECU. i tore the steering column apart so i could get a better ground, and beleive me it is well worth it to pull out the 3 screws and take it off. gives yuo a lot more room.
Old Apr 22, 2007 | 04:33 PM
Car Info: 2003 wrx
I was just out playing around with it again and found that when i just turn the key to the accessories ON position, set the timer, then pull the key out it will work and counts down but if i turn the car all the way on and try the same thing, it shuts right off. I have redone all the wiring (2 wires) except for the one to the ECU. so i am hoping that it has something to do with that. any suggestions?
Old Apr 22, 2007 | 05:06 PM
strider327's Avatar
Car Info: 2005 WRX
Reset ECU....same thing happened with my apexi. You should be fine afterwards. Take off the negative terminal on the battery.
