Turbo Port and Polish ?
Old Nov 28, 2004 | 08:31 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Question Turbo Port and Polish ?
LIC Motorsports in Navato has a P&P for turbos and I was wondering if anyone had done this, or seen results on how much it gives you.
FYI I am thinking of doing this to a VF-34 that I have set to go on my car.
Rush
Old Nov 28, 2004 | 08:38 PM
ScoobyStas's Avatar
Car Info: Sonic Yellow WRX
have heard that a pnp moves ur curve a bit left and gives maybe 200rpm quicker spool.
Old Nov 28, 2004 | 08:43 PM
WRX Rush's Avatar
Cool thanks for the info, anyone else have any experience ?
Rush
Old Nov 29, 2004 | 08:46 AM
wssboard18's Avatar
I had my vf22 p&p at Lic and when i got tuned the tuner said it was much easier to control the boost b/c of the ported wastgate. As for power gains i cant tell you b/c I didn't do any before and after tests. I can only assume that if you can control the boost better than then you should be able to control and fine tune a little more. I also know that it helps with spool up and boost creap, epecially if you have a 3in tbe without a cat. If I had to do it again and spend the money I would. I feel that it helps tune for the turbo better and helps the effeciency of the turbo. Oh yeah, I would recomend getting it done at Lic. They are great!!
cutro64
Jan 14, 2010 11:17 AM
chochocho
Mar 9, 2008 04:49 AM
mpower22
Aug 25, 2004 12:52 PM
tim
13
Dec 2, 2003 11:37 AM
pierceman
Nov 27, 2003 10:36 PM
