Turbo going bad?
Old Dec 29, 2006 | 07:40 PM
strider327's Avatar
Car Info: 2005 WRX
Okay good, I'm ruling out misfires and other major problems. So it has to be exhaust leak. Might as well just upgrade bro, but just do the test when you can first and let me know what happens. Where you see the smoke accordingly and all that. But besides that upgrade and the problem should go away. And a tune up shouldn't hurt either, if you haven't done so already.
Since your almost at 100k
I would recommend the following:
Spark plugs
Timing belt, tensioner belt/Water Pump
Differential Fluid/Transmission Fluid
Coolant
Fuel Filter (Depending on what year your car is)
And inspect your brakes.
Old Dec 29, 2006 | 07:53 PM
wrxugly's Avatar
I will do the test tomorrow and let you know. thanks for the words of wisdom.
tune up done 2000 miles ago, except for timing belt and water pump.
my car is an 03.
Old Dec 29, 2006 | 07:58 PM
strider327's Avatar
Car Info: 2005 WRX
No problem, good luck.
Old Dec 29, 2006 | 08:01 PM
wrxugly's Avatar
thanks
Old Jan 2, 2007 | 01:33 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Do you have a boost gauge and if so is boost fluctuating? It sounds like the oil seal in the turbo is going out and that is a VERY common problem.
strider327
I know you're just trying to help but I think you're waaaay off in your analysis and you might make this guy spend money on parts that won't fix the problem. What exhaust gasket around the turbo would cause oil to leak? I don't see how an exhaust gasket could make the car smoke only coolant or oil can do that.
Old Jan 2, 2007 | 01:37 PM
strider327's Avatar
Car Info: 2005 WRX
Yeah I understand what your saying, that's why I told him to have it checked out. He didn't say it was leaking oil or anything but just twice he had a small cloud of smoke. And on top of that just the smell of a leaking exhaust smell, so first came to mind was a busted gasket or some nature to that. Well in any case I hope he gets it fixed. Good Luck and thanks for clearing up some gaps that I didn't address. But yeah I totally agree with you that it probably is the oil seal around the turbo, it had to be some kind of seal that would be causing a leak.
Old Jan 2, 2007 | 01:48 PM
MO REX's Avatar
I'm not trying to bust your ballz or anything but I believe it is important to only comment on things you have experience with and if you don't explain that you have no experience. If you just go off what you read you will be more likely to spread misinformation. When I first bought my WRX in 02 I was also guilty of making this mistake so don't think I'm trying to be a dik, I'm just trying to help the community.
Old Jan 2, 2007 | 02:14 PM
strider327's Avatar
Car Info: 2005 WRX
All good no worries, gotta learn some how.
Old Jan 11, 2007 | 06:46 PM
wrxugly's Avatar
Thanks for the help guys. I decided to go out and buy a 2007 WRX. I'm way STOKED! IT IS SO SICK!
Old Jan 11, 2007 | 07:08 PM
MO REX's Avatar
Congrats on the sweet car. Did you get the TR? The 2.5 makes me want to do the same thing but I'm a huge bug eye fan so that's holding me back.
Old Jan 12, 2007 | 06:09 AM
wrxugly's Avatar
Thanks. No I didn't get the TR, straight up WRX. The TR is a little cheaper than the WRX and it looks like it. I'm a HUGE bugeye fan too, but the 07s grew on me.
Old Jan 12, 2007 | 10:29 AM
strider327's Avatar
Car Info: 2005 WRX
Congrads with the new improve.
Old Jan 12, 2007 | 02:25 PM
MO REX's Avatar
Yea, I hated the new body style when it first came out but now I think they look great. Hell I thought my bugeye was horrible looking when I bought it in 02 but now I love the look of it.
Enjoy
Old Jan 12, 2007 | 06:44 PM
wrxugly's Avatar
Thanks for the help and thanks for the congrats!
Old Jan 12, 2007 | 06:47 PM
wrxugly's Avatar
Enjoy
All WRXs look crappy, until you do them up. Its crazy what just a set of wheels and springs can do to a WRX.
