Thread lock on Galley port
Old Nov 2, 2005 | 07:43 PM
EnderW's Avatar
Car Info: 2002 WRX
Question Thread lock on Galley port
I am installing a oil pressure sender via a Aeroquip braided line to the oil galley port under the I/C on an EJ20T.
Is it best practice to use some sort of high temp sealer or thread lock on the adapter going into the galley? If so which one?
Also, I was wondering about the fittings on the braided lines, is teflon tape enough to seal them? I am finding that for NPT threads most people recommend this TFE Paste, is that what you guys are using?
Edit: I did find that you are not supposed to use any type of sealer on AN threads, in case this helps anyone else out. Reference: http://www.aeroquip.com/media/techtips/TipAdapters.pdf
Edit: Further info from NASOIC: The torque specs on the galley port are ~30FtLbs, according to docs provided by www.wrxtra.com with their sender kit.
Old Nov 3, 2005 | 04:31 AM
04blkWRX's Avatar
Car Info: Black WRX, stock
I did the same install...I used high-temp teflon grease on the gallery plug and teflon tape on the fittings (they are mostly NPT with one BSPT). I haven't had any leaks in the year that's it's been in place.
Old Nov 3, 2005 | 07:29 AM
EnderW's Avatar
Car Info: 2002 WRX
Thanks, I will use teflon paste/grease on the galley threads as you did. I assembled the NPT/BSPT parts already with teflon tape. So I think I am good to go now.
O/T, that aeroquip braided line is nice, a little hard to assemble, but man rock solid.
RedForce1
Nov 30, 2012 07:12 AM
dub81
Hawaii Classifieds
Jun 13, 2006 11:17 PM
the5ilenced
May 28, 2006 02:45 PM
Peaty
Aug 28, 2005 03:24 PM
dr3d1zzl3
Jun 28, 2004 06:41 PM
