Which of these 2 up pipes is the best?
Old Jan 10, 2003 | 12:06 AM
scoobiesnacks's Avatar
Perrin I likey
Old Jan 10, 2003 | 11:06 PM
nqwan's Avatar
Car Info: o2 duburu arr exu
the vishnu is made with better metal but is more expensive than the perrin. neither will leak assuming proper installation and good gaskets. really, just pick one that has more features that are useful to you.
Old Jan 10, 2003 | 11:23 PM
supermarkus's Avatar
I want to point out that they are both made out of 321 stainless now. The new Vishnu with the flex joint is made of 304.
Old Jan 10, 2003 | 11:27 PM
nqwan's Avatar
oii, when did perrin up their steel to 321?
thanks for the correction, i dont want to spread around wrong info.
Old Jan 11, 2003 | 01:22 AM
Wingless Wonder's Avatar
Re: Which of these 2 up pipes is the best?
Originally posted by spdkills
the Vishnu that comes with the complete kit or the Perrin? Also Which is less prone to leaks?
Vishnu up-pipe $309 - parts page:
http://www.vishnutuning.com/parts.htm
Perrin up-pipe $249.99:
http://www.perrinperformance.com/pro...ipe/UPPIPE.htm
Both up-pipes are constructed of 321 stainless steel, with 1/2" flanges.
__________________
ww
Old Jan 11, 2003 | 02:48 PM
Their first couple generations of the pipe were 304, I believe they're on their 3 iteration. It's 321 steel with a bead blasted finish, very tasty, as is their downpipe I believe.
Old Jan 11, 2003 | 04:18 PM
Vishnu's Avatar
Car Info: 996 Turbo,Gallardo,BMW 335,125cc shifter kart,etc
Originally posted by ShotgunTC88
What do ya guys think of the Pro/Con of havin the Flex vs. The solid Upipe?
I think the Vish Flex is a great idea for the less "mechanic inclined" guys to keep out leaks?
Thoughts on longevity/performance/etc?
SHotgun
Our take on the matter is pretty simple. For a street driven car, a flex 304 will provide years of trouble-free use. The existence of the flex joint will relieve much of the bending stresses a rigid pipe would see during normal thermal cycles (expansion and contraction). For cars that see track days where EGTs exceed 1500F for prolonged periods of time, the 321 rigid pipe is our recommendation. Not having a flex joint means that there is more stress on the pipe itself. But that is accounted for by using the higher grade steel and doubler/reinforcements on both ends. These doublers releive much of the stress that would otherwise be placed on the weld joints during thermal cycles (where the pipe is most likely to fail.) The use of these doublers, which we're had from the start, is one reason our pipe is more expensive than others.
Just my 2c,
shiv
________
Hawaii dispensaries
Old Jan 11, 2003 | 04:24 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Another benefit of the flex pipe, is leak-free fitment.
I have seen and installed over 20 uppipes myself and there are lots of variations in stock WRX manifold and the aftermarket ones. Solid pipe allows for minimum variances, since any more than the pipe can bend/flex (which isn't a lot) will result leaking.
The pipes with flex joints, can be fitted even to the most poorly made manifold that is way off the original WRX manifold.
I myself use VISHNU solid pipe since day one. I, as a matter of fact, have THE first one ever made and it is still solid as a rock, leak free, crack free and rust free.
My car have seen EGT's, boost and power that most cars haven't seen.
- Alex
Old Jan 11, 2003 | 05:30 PM
IS2Scooby's Avatar
Pr0n King
Car Info: Turncoat Turbo
Now that's a personal testimonial to write home about!
__________________
