taking off TMIC
Old Apr 8, 2004 | 09:46 PM
nic3krnnamja83's Avatar
taking off TMI?????
is there anythig i should worry about, imma change my tranny oil so i was wondering if there any precautions or fluids i should be aware of. Also is there any installl instruction i can see. I cant find any on scoobymods, just the how to on changing the oil.
thanks brandon
Old Apr 8, 2004 | 11:41 PM
orwrx's Avatar
Car Info: WRC replica
Actually you can change your tranny fluid without taking the IC off. What you do is, go buy a hand oil pump with long hose from autopart store and just pump the fluid in the digstick hole. You will figure it out man. If not, drop me a pm.
Old Apr 8, 2004 | 11:55 PM
hey thanks
Old Apr 9, 2004 | 10:30 AM
Peaty's Avatar
There are directions there on scoobymods, I just did mine on my F-XT too and there is no need to remove the IC as stated, just use a funnel and some tygon tubing.
Pretty much the same on the WRX, How to here:
http://www.scoobymods.com/forums/sho...y+fluid+change
PS since Scoobies are pretty much the same across the line when working on many things, Legacy, Impreza and Forester it's best to search scoobymods and not just look in a particular section.
Peaty
Old Apr 9, 2004 | 12:56 PM
lol thanks peaty yeah i was just looking at wrx at scoobymods. i will make a note next time to make sure and search across the board
just to add, that was a great link, and exquisit detail
Old Apr 11, 2004 | 09:43 AM
Magish's Avatar
Yeah, peaty is awesome in that way
Old Apr 11, 2004 | 03:39 PM
lol, i think someone is jealous
Old Apr 14, 2004 | 11:23 PM
DJTEN4's Avatar
Car Info: 03 yellow wrx
how long does it take to take of the tmic, when switching dp, the tmic should be removed, but how hard is it
Old Apr 14, 2004 | 11:36 PM
not very hard
Old Apr 15, 2004 | 06:11 AM
speedfreak's Avatar
Car Info: 2002 Impreza WRX | 1987 Mazda RX-7
Easy, 2 bolts on the sides of the intercooler and then 3 on the front holding on those hoses. Then all you have left are the throttle body hose clamps and the home clamp on the turbo. The real ***** I've found is getting it all back on! Trying to get the throttle body hose connected and y hose under the intercooler connected back on to the turbo is a real pain There might be some trick to it, but I haven't figured it out.
Old Apr 15, 2004 | 08:48 AM
DJTEN4's Avatar
Thumbs up
thanks
Old Apr 15, 2004 | 11:44 AM
esracer's Avatar
Car Info: 2002 Honda S2000
You shouldn't have to take off the tmic to switch downpipes, I switched mine out without taking the tmic off with no problem. I would try to put the pipe in without taking the tmic off first, then if you can't, take off the tmic.
Old Apr 15, 2004 | 08:48 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
The trick is to heat up the stock one, or get a silicone Y hose and put it back on in two seconds!
Old Apr 16, 2004 | 04:26 AM
speedfreak's Avatar
Actually, I got a silicone hose kit (y pipe, throttle body, bov) from rallitek.com. I couldn't decide if I wanted the Perrin one or the other one they offer (GPMoto?) because there was about a $50 price difference. I think I made the mistake and went for the cheaper one. The fitment of the y-pipe totally sucks. With the hose clamped down to the two inlets under the intercooler, there isn't enough hose to get it to fit nicely on the turbo. I spent hours trying to get it back on.
Impreza_WRX_STi
Dec 1, 2003 11:34 AM
NewShockerGuy
Jul 6, 2003 12:16 AM
Buzzman
Jan 13, 2003 11:52 PM
kenchan
Dec 23, 2002 12:44 PM
kenchan
Dec 19, 2002 01:29 PM
