Suggestion on up-pipe
I'm sure this question has come up in the past, but I need some new ideas. I have an 04' wrx and I want to get an up-pipe. I'm not sure which up-pipe I should get. I know that the sti comes with an up-pipe that has no cat. If I was to get that, would I be able to still pass smog? Do any of you guys have suggestions or websites that I could go to? Could you also let me know roughly the price of an up-pipe? Thanks!
Car Info: was 05 WRX Wagon
Go w/ the Helix Flex up-pipe. The flex design prevents leaks in the long run; not to mention the cost which is less than most up-pipes out in the market.
As for a vendor, can't go wrong w/ Mike @ www.mpjperformance.com.
-Soren
-Soren
Car Info: want a WRX
^ agreed. http://gruppe-s.com/ also has great prices...if you're not worried about leaks go with vishnu, if ya are then helix is a great choice.
Car Info: 2004 Subaru WRX (Silver Sedan)
Yeah, go with Mike over at MPJ. He's hooking me up with an awesome package right now on a Helix up/dp combo with a Borla Hush! Can't beat it.
The Helix uppipe also flexs so you can get a perfect seal.
Re: Suggestion on up-pipe
-Chris
hey i got a question? Is your hush gonna match up with your helix downpipe? Cuz I have a hush with a helix flex uppipe and ive heard that the downpipe doesnt mate very well with the hush.......?
You are correct, there will be fitment issues. From what I understand the cat back needs a new flange welded to it in order for there to be a proper fit. I know MPJ can do that work in-house.
-Chris
-Chris
Yeah, you'll need a flange, but MPJ doesn't have them right now. Just go to a muffler shop or go buy a flange at an autoparts store and find someone with a welder. You'll need a 2 bolt flange or convert it to 3 bolt.
Thanks for all the advice! Have one more question. Will the sti up-pipe make that much of a difference or should I fork out the extra money and get the helix or vishnu
-Chris
