Strange noise?
Old Oct 19, 2005 | 11:14 AM
Yepwrx's Avatar
Unhappy Strange noise?
Recently I been hearing a strange noise almost like swishing or gargling water when I lightly rev the car? It seems to happen more oftem when the engine is cold. Any idea's?
It goes away when the car is warm but only has happened to me once.
Does anybody know?
Old Oct 19, 2005 | 11:54 AM
yzercyber's Avatar
Car Info: 03 WRX Sedan MBP/17X7.5 SSR Comps/225 Kumho MX
Your post seems a little contradictory. You say the gargling happens more often when the car is cold. Then you say the sound went away once when after the engine warmed up.
I'm assuming you are driving a more or less stock impreza. Is your coolant reservoir dry (coolant level is below the fill hose) when the car is cold? Any coolant leaks?
Old Oct 19, 2005 | 12:03 PM
subie OCD's Avatar
Car Info: 04 STi
Air bubbles in teh coolant system
Old Oct 19, 2005 | 02:18 PM
Yepwrx's Avatar
noise
When I started my car up at my brothers house the car was cold and there was this gargling sound that I could hear from the inside of the car. When I rev it a little the gargling sound was louder. I waited for the car to warm up a little bit more then I drove home. And there was no sound. I was just wondering if this is just normal and the car was just cold.
Old Oct 19, 2005 | 11:11 PM
yzercyber's Avatar
It's not normal for the car to do this either cold or warm. The first thing I'd check is the cooling system.
Old Oct 20, 2005 | 01:30 PM
mbquarts's Avatar
Car Info: 03 MBP WRX
Its not normal...your coolant reservoir is empty. This is OK if you just had maintenance done, but if you havn't then you have a coolant leak.
STi4life
Mar 1, 2004 11:09 AM
osidescooby
Dec 22, 2003 10:52 AM
VitaminWRX
Nov 1, 2003 12:58 AM
ppat
Sep 12, 2003 08:34 PM
boynty77
Dec 24, 2002 10:13 AM
