stock detonation
Old Oct 30, 2003 | 01:59 PM
samagon's Avatar
stock detonation
I just recently got a WRX, it has a bit more than 3k miles, I love it, problem is, that about halfway through 3rd, hard throttle, it sounds like it is detonating. anyone else experience a similar effect?
I am planning on getting the cobb reflash, and probably an exhaust, will this have any effect at all (pos, or neg)?
also, I notice that it does it more after I am accerating to get on the freeway after sitting at a light, I haven't tried getting off the freeway and getting right back on to bring it through third again, but that is next on the list (edit: meaning heatsoak could be the problem).
any thoughts or ideas?
and not that I am afraid of the dealer, but after reading how a lot have been treated, I feel I may be treated with indiference.
Old Oct 30, 2003 | 02:12 PM
John #555's Avatar
Car Info: 02 WRX
I had detonation when my MAF went bad - $$$!!! are you using aftermarket air filter? I think mine was caused by too much oil on my air filter (ITG foam).
i think the reflash would definitely help if everything elses in working order.
Old Oct 30, 2003 | 04:34 PM
Magish's Avatar
MAF could very well be the problem so check that soon...
Old Oct 30, 2003 | 06:12 PM
Do you have any mods? If not, I would expect it to be heatsoak, especially if the knock doesn't return once you've been at freeway speeds for a couple minutes. Check out the article in this month's SCC for some itneresting data on the stock intercooler.
Old Oct 31, 2003 | 04:42 AM
andyhidley's Avatar
Car Info: 2002 WRX
yup, OIL ON THE MAF. Happpened to me. I gently cleaned it off with gas and it fixed my problem....
Old Oct 31, 2003 | 08:09 AM
samagon's Avatar
no mods
I have no mods, and I can't think of how oil could have gotten into the MAF, but I will check it.
I think you are probably right BAN, I was thinking this myself, but just wanted to get confirmation from some people with more history with the WRX, and turbos in general before I jumped to conclusions. I will check out that article some time this weekend (as well as the MAF, just in case, when I pull out the silencer).
Thanks again guys
Old Oct 31, 2003 | 08:59 AM
John #555's Avatar
Car Info: 02 WRX
samagon,
if you're using stock air filter dont worry about MAF. in fact, MAF is very delicate so it's probably better if you dont mess with it.
Personally, I never experienced detonation due to heat, not even in Las VEgas heat during summer. I hope the reflash fixes all your woes. Cobb is the path i'll be taking soon as well, to cope with my misfortune - my buddy just got a STi.
Xtremewrx
Jun 23, 2003 07:19 AM
bluesubeguy
May 23, 2003 11:18 PM
ShotgunTC88
Jan 31, 2003 09:11 PM
UU R X
Dec 14, 2002 11:24 AM
